Home > Wheels & Tyres > ET0 Offset Rim as a Spare?
JOW240725
If you run ET0 rims should you match the spare wheel with same offset? Confused
I'm just thinking maybe the standard off-set would be better for the spare (whether it be on the rear door or bonnet) to keep it closer to the body, less stress? But is it OK to temporarily run a standard offset rim when the rest are ET0?
TIA Bow down James
Instagram @suffolk_rovers
Post #741265 19th Nov 2018 4:22pm
grafty99
The advantage to having a non matching spare is that it forces you to get the punctured tyre sorted (instead of not getting that done next week Whistle )
I'd imagine though that it would be horrible to drive if it were on the front.
I have an 18" ET10 on my back door with no ill effects Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #741283 19th Nov 2018 6:22pm
Grouse
Yes I have done this - no worse than a space saver as long as the diameter of the tyre is the same
Post #741296 19th Nov 2018 7:54pm
