Home > Technical > Battery Cable Routing
need4speed
Could someone maybe post a pic of the live cable that runs from battery across the seatbox to the fusebox.
The cable that attaches to seatbox by means of a metal bracket. 4.6 RV8 110HT
Post #739955 11th Nov 2018 9:43pm
Romadog
Question Question Question Question
Didn't know one did
Post #740199 12th Nov 2018 10:18pm
landy andy
There is one live cable that goes direct from pos term on battery, across back of battery box, then into conduit and over the top of transbox, then into under drivers seat box onto fuse box there. Is that the one one you are asking about?
Andy
Post #740209 12th Nov 2018 10:53pm
This cable is one of the main security vulnerabilities of the Defender, and in consequence you may find people are a bit cagey advertising its location. If you are asking because you want to renew/replace it, you may want to consider running it via a route that affords adequate protection rather than as it would originally have been routed.
Post #740239 13th Nov 2018 8:35am
need4speed
It’s got a 90 degree terminal at 1 end that goes to fuse box, and a bolt at other end that goes onto battery terminal clamp. 4.6 RV8 110HT
Post #740320 13th Nov 2018 6:25pm
landy andy
Ahhh. So your talking Tdci stuff.
Post #740394 13th Nov 2018 9:15pm
need4speed
Nope. TD5 loom. 4.6 RV8 110HT
Post #740575 14th Nov 2018 9:05pm
Mine fit by some push on plastic clips (under the seatbox), these clips push onto the exposed threads of some of the bolts that poke through.
Think they're moulded with cable ties so the loom just "zips" up into place.
Post #740627 15th Nov 2018 6:56am
