Home > Maintenance & Modifications > LR008247 steering guard parts help.
24heuer
Scotland 2010 Defender 110 Puma 2.4 CSW Keswick Green
Hi all,
I bought a used one of these as a bit of a project to do up.
Just looking at gathering all the fixings together and a couple of bits have me stumped - see pics.
I think one is just a large, thick M12 washer.
Not sure about the other though.
Anyone got any clues?
Many thanks in advance Bow down
 Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #738577 4th Nov 2018 4:06pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
I removed and refitted the (similar) Adventure steering guard when dinitrolling the chassis. From memory, I think the smaller one is effectively a sleeve, as the hole in the side bracket is larger than the diameter of the bolt and the larger one is just a large washer.
I'll try and take a photo of the bolt head tomorrow.
Maybe the hole in the bracket is oversized to allow fitting to left hand drive vehicles? Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #740381 13th Nov 2018 9:41pm
24heuer
thanks Doublea,
I think that's exactly right and what I bought in the end.
I had to stick it in the local garage to get the work done as (is usually the case with my Defender) even the simplest things turn into a major project and I just couldn't get any of the existing bolts free Big Cry
Anyway it's fitted and looking good Smile Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #740428 14th Nov 2018 12:27am
NIBrown
United Kingdom 2002 Defender 90 2.5 TD CSW Epsom Green
STEERING GUARD FIXING KIT
Hi Andy,
Just bought one of these guards for myself and like you struggling to get a fitting kit together.
I don't suppose you would have a definitive list and maybe a supplier for them please?
Thanks,
Nick
Post #801204 7th Nov 2019 2:52pm
24heuer
Hi Nick, such a long time ago Smile
I bought all of the parts using the diagram at the top of the page as my shopping list, with the info from Doublea.
Nuts, bolts and washers all came from here -
https://www.accu.co.uk/en/
Probably not the cheapest, but decent quality and fast shipping.
I think some of the sleeves came from eBay.
Mine was well used before I got it so I also replaced the 8 nuts/bolts that hold the frame to the guard as they'd seen better days.
I plastered the frame in Antirust primer and dinitrol too.
I also heavily lacquered the guard both sides and it's held up pretty well.
Oh, also, if you don't have the instructions, I can email them to you or they are downloadable from the LR TOPIx site.
Hope this helps,
Andy... Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #801210 7th Nov 2019 3:18pm
djb
Northern Ireland 2014 Defender 110 Puma 2.2 SW Corris Grey
Hi Andy. thanks for the info on the steering guard. I am just about to buy a used one too and i noticed you had the fitting instructions. I know its quite a while ago for you and might not have these to hand. I looked on the TOPIX site but cant seem to find them? If its not too much trouble id be very grateful. my email is (removed by admin for safety)
Regards
David
This post has been edited by the site administration team
Post #879439 19th Jan 2021 12:57am
Martin
Site Admin
Instructions: https://www.defender2.net/forum/post184629.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #879442 19th Jan 2021 1:28am
djb
Hi Martin. Thank you for these. Excellent.
david
Post #879443 19th Jan 2021 1:36am
djb
Hi Martin, i dont suppose you know the size of the 8 bolts that hold the alloy guard to the metal frame? From photos they look like M8 HEX head button's? i dont have the guard as yet and am trying to pre order all the nuts and bolts needed for the fitting.
cheers
david
Post #879969 21st Jan 2021 6:03pm
Martin
Site Admin
I don't (I've not got a guard) try a PM to 24heuer - he rebuilt his as in the pics above Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #879978 21st Jan 2021 6:46pm
djb
Thanks Martin
Post #880047 22nd Jan 2021 1:30am
Beco90
Hi all,
I bought the same genuine LR steering guard as above second hand but it didn’t come with the fitting kit. I can get hold of the nuts and bolts from the parts diagram above no problem, however there are several bespoke bolt spacers or ‘sleeves’ shown in the diagram (Parts E, F and G) as well as the unlabelled washer and spacer ringed in red in a previous post above which I will need to get milled by a local engineering shop. The parts diagram only gives one dimension for the spacers: the lengths. Would any helpful forum member be able to advice me on the crucial external diameter of each of the spacers? I’m assuming the internal diameters of the bolts holes are just to match the relevant M10 or M12 bolts.
Fitting kits are no longer available from LR or from any parts specialists I have contacted so rather short on options!
All help greatly appreciated!
Post #1058790 28th Jan 2025 12:23pm
