Home > Defender Celebration Series & Classic Works > Adventure side sill guard removal |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
I'm sure some help will be along shortly. James
MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
3rd Nov 2018 8:51pm |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 |
The alloy plate is one piece which attaches to a heavy sub frame underneath I would remove the alloy plate and Treat the frame along with the chassis 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
3rd Nov 2018 9:46pm |
APK Member Since: 13 Jan 2015 Location: London Posts: 255 |
Thanks, I decided to leave them in so the whole setup gets treated. Based on www.defender2.net/forum/post609736.html it does not look like the alloy plate is easily separated from the sub frame without proper access under the vehicle. The bottom row is not a problem, but the top row is not easy to access. If you know of any wax/polish that is suited for this piece, I would really appreciate it. Thanks APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
4th Nov 2018 12:25am |
Take them off as you wont get the protection on the part of the bracket that’s actually need,
I would speak to Craig at buzzweld and get some fx2k made in silver and coat them no more corrosion or problems then Failing that still speak to Craig as he can do you a clear etc lacquer to go on the plates to protect them if you want to keep original finish 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
4th Nov 2018 8:48am |
dotom Member Since: 04 Feb 2012 Location: Dortmund Posts: 90 |
Hi, as i put the Adventurer sills to my 90 I can say that it’s easy to remove them. It would be good to have a helping hand to prevent them from falling down. If you have them apart you should think about getting them galvanized. I’ve done that before the first install so they are well protected. The frame is protected with underbody spray.
Best regards Tom |
4th Nov 2018 1:31pm |
Thanks Tom & PJ2106
Is anyone aware of the Parts Catalogue for the Adventure 110? Much like... http://www.retroanaconda.com/landrover/par...94-923.pdf Thanks APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
4th Nov 2018 10:50pm |
