Home > Defender Celebration Series & Classic Works > Adventure side sill guard removal
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Hi all,
I need to remove the side sill guards from my Adventure 110.
I am getting a rust treatment done underneath and would like to know what to expect before I attempt to remove it.
Assuming fellow Adventure owners may have some experience removing the sill guards (and front guard hopefully).
1) May I know if it is a matter of simply unscrewing the 7/8 screws along the side or is it a little more complex than that?
2) They seem to attract a lot of white residue. Appreciate any tips on wax / polish to get them clean while they are off.
3) Would you know the LR part number for both sill guards?
Many thanks! APK
MY2016 110 Adventure Corris Grey
MY1997 110 County Station Wagon 300 Tdi Alpine White
Post #738467 3rd Nov 2018 9:06pm
JOW240725
I'm sure some help will be along shortly. Thumbs Up James
Instagram @suffolk_rovers
Post #738470 3rd Nov 2018 9:51pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
The alloy plate is one piece which attaches to a heavy sub frame underneath I would remove the alloy plate and Treat the frame along with the chassis 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #738478 3rd Nov 2018 10:46pm
APK
Very Happy
Thanks, I decided to leave them in so the whole setup gets treated.
Based on www.defender2.net/forum/post609736.html it does not look like the alloy plate is easily separated from the sub frame without proper access under the vehicle. The bottom row is not a problem, but the top row is not easy to access.
If you know of any wax/polish that is suited for this piece, I would really appreciate it. Thanks Thumbs Up APK
Post #738487 4th Nov 2018 1:25am
pj2106
Take them off as you wont get the protection on the part of the bracket that’s actually need,
I would speak to Craig at buzzweld and get some fx2k made in silver and coat them no more corrosion or problems then
Failing that still speak to Craig as he can do you a clear etc lacquer to go on the plates to protect them if you want to keep original finish 2008 110 2.4 XS Utility (Hagrid)
Post #738501 4th Nov 2018 9:48am
dotom
Germany 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
Hi, as i put the Adventurer sills to my 90 I can say that it’s easy to remove them. It would be good to have a helping hand to prevent them from falling down. If you have them apart you should think about getting them galvanized. I’ve done that before the first install so they are well protected. The frame is protected with underbody spray.
Best regards
Tom
Post #738556 4th Nov 2018 2:31pm
APK
Thanks Tom & PJ2106 Thumbs Up
Is anyone aware of the Parts Catalogue for the Adventure 110?
Much like...
http://www.retroanaconda.com/landrover/par...94-923.pdf
Thanks APK
Post #738692 4th Nov 2018 11:50pm
