Home > Td5 > TD5 takes forever to warm up
Page 2 of 2 <12
rallysteve
I found mine runs much cooler when the winch and spot lights arnt fitted! Laughing
Post #737615 30th Oct 2018 5:23pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
So this morning I took a bit longer getting ready... and my truck was running closer to 15 minutes, and it was fine by the time id driven 100yards up the road.. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #737788 31st Oct 2018 12:14pm
bigfatsi
United Kingdom 2003 Defender 110 Td5 CSW Aintree Green
Thanks for the replies.
I like the idea of the radiator muff, but I'm not sure if it would fit behind the soft A' bar. And they're fugly to me. Sorry.
This weekend I'll be putting all the suggestions to good use - flush, check pipes/joints, stat, cap, OAT antifreeze etc - and I'll let you know how I get on. I know from my last rebuild that the bulkhead gaskets degrade, but I doubt I'll be going that far right now.
Thanks again!
S
Post #737797 31st Oct 2018 1:54pm
Retroanaconda
I would suggest that 15 minutes idling from stone cold is not particularly good for a diesel engine.
Post #737809 31st Oct 2018 3:43pm
Adam17
Ah ok.. usually only 5-10 mins.
How comes anyway? Sorry im not mechanically minded, but am learning... fast.. Regards
Adam
Loving The Duchess
Post #737826 31st Oct 2018 4:44pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
Viscous fan functioning as it should ?
Post #737836 31st Oct 2018 5:33pm
Retroanaconda
It can damage the bores through glazing, with no load and thus cold temperate internally.
Low chance I would say, but nonetheless diesels like being worked hard. They’re happiest under load Thumbs Up
Post #737859 31st Oct 2018 8:07pm
Laurie
Ultimately, if you want a quick warm-up, fit a V8! Very Happy
Post #737925 1st Nov 2018 1:12am
Adam17
[/quote]
Low chance I would say, but nonetheless diesels like being worked hard. They’re happiest under load Thumbs Up[/quote]
Ah ok.
Thank you, ill bear that in mind over winter - its a habit I have had with my previous diesels.. Ill break out of it sharpish.!! Regards
Adam
Loving The Duchess
Post #737983 1st Nov 2018 12:53pm
pistonbroke
After the coolant system flush what antifreeze do people reccomend replacing it with in the TD5?
Post #737995 1st Nov 2018 1:49pm
Adam17
Hi buddy,
Its been bugging me about this idling business, so I have been doing a bit of digging, ill continue to dig until I source some solid trustworthy advice...
But I found this...
https://www.quora.com/Do-diesel-engines-ne...of-minutes
--particularly this section--
The one other feasible time (other than just using the engine as a generator of electricity) would be warming up on a cold day. A diesel does not combust well cold. Letting it warm up, unlike a gasoline engine, can be better for it and its emissions systems because, even though its not burning well at idle in the driveway, putting more fuel in the system, though drastically reducing heating time, will be drastically introducing soot to the particulate filter.
This doesn’t mean idle the truck for 45 minutes till its toasty warm… just a few minutes to get the metal directly around the combustion chambers hot. Also, plug it in.
which confused me its kind of saying its good and bad Laughing Regards
Adam
Loving The Duchess
Post #738037 1st Nov 2018 4:59pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Mine has had....
Heater matrix replaced, it was part blocked.
New cap on the expansion bottle.
Cooling system flushed.
Heater adjusted.
All gaps taped up with silver tape so less draughts.
New fan with a bulge blower on the inlet to the fan.
The adjustable knee height vents from the guy on here.
The whole motor is dynamic matted.
I don't put the heaters on till they start blowing warm 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #738219 2nd Nov 2018 7:02pm
voorfrank
Netherlands 2002 Defender 110 2.5 TD SW Bonatti Grey
Some time ago I found a diascussion where they mentioned that in the freelander the same model thermostat is fitted.
From LRDirect:"Thermostat housing with part number PEL500110 fits to the Freelander 1 with the 1.8 petrol engines and also to the Discovery 2 from 02"
If you look at this site, you see that there are three different types/opening temperatures. https://www.autodoc.co.uk/car-parts/oem/pel500110
A few degrees makes a big difference.
Post #738991 6th Nov 2018 11:27am
OsloBlue
Mine is nice and toasty, gets warm when the temp gauge just leave blue.
I've found that the blower only wants to work on the bottom three settings, which is ever, So much blow you can't open your eyes, Middle whish is noisy, or lowest which does little but trickle heat through
mmmmm heat so toasty you could nap... Yawn I'm on IG: https://www.instagram.com/osloblue42/
Post #738995 6th Nov 2018 12:09pm
rallysteve
The blower is only 2 speed so only the bottom two settings will work Laughing The movement of the slider above this opens and closes the air flap on the back of the heater box. 02' 110 TD5 Double Cab Rebuild Thread
Post #738999 6th Nov 2018 12:19pm
Page 2 of 2 <12
