Home > Puma (Tdci) > 2.4 tdci injector advice please
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Had a brand new engine fitted to the 2011 model 110 USW back in January. Replaced the turbo with a new OEM one BUT "saved" a bit of money by having recon injectors fitted.
All O.K. and running well but unable to do pump learn or injector pilot learn with Nanocom or BAS RRC.
The injector codes went into the ECU no problem.
Replaced the VCV on advice from Pete at BAS, and the mechanic was able to perform the Pump Learn but not the Pilot Learn.
From new engine to "forced" pump learn was around 7.000 miles and its done around 10000 without the Pilot Learn.
I've decided to replace the recon injectors with new ones, (several posts on here suggest that recon injectors have learning problems)!
Land Rover dealer quoted genuine at around £400+VAT each or OEM at £230+VAT. there are others advertised as OEM at around £190+VAT.
The Defender is a keeper, does at least 15000 miles p.a. and is my daily driver.
The question is, based on your experiences, what injectors do you suggest I have fitted, and where can I get a reasonable deal?
Thanks.
Post #733704 8th Oct 2018 7:59pm
rossy
Ouch 400 quid each ! Don't do it !
I have a 2011 2.4 and had to change the injectors 18 months ago primarily because the copper seals had worn (as they all do) causing overfuelling and 'ballooning' at the tips. Admittedly I was a bit lazy and did nothing about it for 10 months. I almost went down the reconditioned route but the cost saving against new was minimal.
Firstly they must be Denso. Period. Secondly, forget JLR or Ford for supply. Find a Transit parts specialist - there must be loads of them in the UK. I got mine from one here in Ireland and paid € 190 each which equates roughly to £ 165. Unfortunately I don't have the part number but if you ask for the ones for Mk 7 RWD Transit they're the same. And get 4 new washers, 4 clamp bolts and the little green o rings for the return pipes. When mine were fitted they pilot learned first time and have been fine since. Smile
Hope that helps
Post #734082 10th Oct 2018 6:48pm
NickMc
Try Frida at Turners? I’m not sure what price they are from them to the general public, but I think about £185? Always great to deal with and know their onions Thumbs Up
https://www.turnerengineering.co.uk/Mobile...2x26001213
Post #734113 10th Oct 2018 8:11pm
MK
I believe part number is 095000-5810 Denso Puma 110" SW
Post #734145 10th Oct 2018 9:34pm
Porny
Site Sponsor
I'd use Brand new Denso Only - with page discount can do them for £155 + vat each including new seals.
Then £8.00 + vat for the 2x bolts needed.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #734190 11th Oct 2018 11:38am
shropshiredefender
Thanks all, that seems pretty unanimous Thumbs Up
Post #734195 11th Oct 2018 11:57am
Deerfold
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
I used recon denso as I was in a hurry and could get them that day, 4000 miles later and all fine.
Post #734286 11th Oct 2018 8:35pm
Grenadier
Following this cloesly, as per another thread, I'm looking to make some mods and also upgrade the engine power. It's idling a little rough, could be hoses, could be a leak, could be injectors, blah blah blah, but wondering if after 60kms, if this wouldn't be worth doing anyway, if fettling with a remap, airbox, hoses, turbo, cooler etc? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #734366 12th Oct 2018 2:35pm
LR only re-box branded parts for significant mark up and Denso is a good brand, so I would go for that.
Genuine does not in all instances mean to say better quality, take fuel tank breather hoses as an example. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #734385 12th Oct 2018 4:11pm
