Home > Expedition & Overland > Green laning??? |
Not my part of the world but have you considered joining one of the local clubs such as http://www.nottslrc.co.uk/
HTH Brendan |
24th Apr 2011 12:09pm |
Landie Boy Member Since: 14 Jan 2011 Location: Essex Posts: 431 |
Hi
Your best bet would be to buy a local Ordinance Survey Map of the area you live in or you could use this website http://www.getamap.ordnancesurveyleisure.co.uk/. Once it loads click "Leisure" in the top left corner of the map . In it it will show all the byways that are in your local area. If your unsure about it, walk it first. Plus remember you are legally allowed to cut any branches, bushes, etc which could cause damage to your vehicle on the route. Jack |
24th Apr 2011 12:11pm |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 |
Where abouts in Notts are you fella?
Drop me a pm - you can come out with us sometime |
15th May 2011 1:35am |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
Only problem with that is that the map will not show what's open and what has a TRO. Best to join a club, or GLASS |
15th May 2011 8:52am |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 |
I agree with BigMike, an O/S map is just the starting point. If the lanes your planning on exploring are local then I would make an appointment with the Rights of Way dept of the local council and ask to view the definative map. The information on there should be up to date and you can then mark up your O/S map with current information. If your traveling some distance and visiting the council isn't practical, then I would recommend joining GLASS or CRAG and registering on this site http://www.trailwise.org.uk/index.php . Unless you've got a second vehicle to go with you and some recovery gear, a club would be the most advisable way to go.
15th May 2011 10:17am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5060 |
a word of warning
greenlanes can easily get damaging if you dont know them or are worried about scratches Mike |
16th May 2011 4:48pm |
