![]() | Home > Puma (Tdci) > Prop Shafts |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
You dont need to remove to grease, just a gun with the right nipple adaptor on it.
If the UJ's are shot there will be play in them, check for play by moving with a long screw driver in the joint, up/down left/right. Should be none or v little. |
fordy103 Member Since: 22 Dec 2010 Location: preston lancs Posts: 85 ![]() ![]() |
cheers mate, is it a fairly standard nipple on them? or a land rover only adaptor?
Standard ball type nipple.
You need a gun and put in one/two pumps, best not to push the grease out of the seals as this buggars the seals up. Land rover do list this as a job on the service sheet. |
