Home > Puma (Tdci) > Prop Shafts
fordy103
2010 Defender 90 Puma 2.4 HT Zermatt Silver
Prop Shafts
Bit of a random question, But was gonna take my props off tommorow and grease them up< and just thought id ask for some tips ?
Ie what grease to use etc
Are the props hard to remove?
And how do i tell if the UJ's need replacing?
Also, do landrover grease prop shafts at main services?
Post #68331 22nd Apr 2011 8:25pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
You dont need to remove to grease, just a gun with the right nipple adaptor on it.
If the UJ's are shot there will be play in them, check for play by moving with a long screw driver in the joint, up/down left/right. Should be none or v little.
Post #68333 22nd Apr 2011 9:00pm
fordy103
cheers mate, is it a fairly standard nipple on them? or a land rover only adaptor?
Post #68334 22nd Apr 2011 9:16pm
Paul_1978
Standard ball type nipple.
You need a gun and put in one/two pumps, best not to push the grease out of the seals as this buggars the seals up.
Land rover do list this as a job on the service sheet.
Post #68335 22nd Apr 2011 9:20pm
