Home > Puma (Tdci) > fitting new chassis: problems to solve
millepet
Belgium 2009 Defender 110 Puma 2.4 SW Orkney Grey
I had an accident with my 110 SW MY2009, and need to put a new chassis under the car (Richards galvanised one).
I am ready to lift the body, but the bulkhead does not move after removing the 2 big bolts running through the chassis and the bulkhead (and all the other bodyfixings to the chassis). Any advice is welcome.
Post #731077 25th Sep 2018 11:46am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Each footwell has two bolts bolted to the chassis via a bracket. Depending what damage you have done it could of twisted around the bulkhead mounting, when I fitted mine I had to splay the bulkhead with a bottle jack to align the bolts, it could just be it’s now held on via friction alone.
Oh always triple check for earth straps as they can test the load limit of the kit you are lifting with Rolling with laughter 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #731198 25th Sep 2018 7:28pm
Here's what to look for
Post #731275 26th Sep 2018 6:04am
NickMc
Have you got the two bolts under the lip of the seatbox mat I’d describe them as the “saddles” ? Either side of the tunnel in the rectangular cut outs in the floor. Lot more brackets and bolts on a CSW.
Post #731433 26th Sep 2018 11:33pm
