![]() | Home > Puma (Tdci) > fitting new chassis: problems to solve |
Each footwell has two bolts bolted to the chassis via a bracket. Depending what damage you have done it could of twisted around the bulkhead mounting, when I fitted mine I had to splay the bulkhead with a bottle jack to align the bolts, it could just be it’s now held on via friction alone.
Oh always triple check for earth straps as they can test the load limit of the kit you are lifting with ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
Here's what to look for
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Have you got the two bolts under the lip of the seatbox mat I’d describe them as the “saddles” ? Either side of the tunnel in the rectangular cut outs in the floor. Lot more brackets and bolts on a CSW.
