![]() | Home > Tdi > Are all roofs created equal? |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I'm thinking about getting a roof without a sunroof as I never really use mine, the alpine window seals look shot and I want to fit a MUD roof console: https://www.mudstuff.co.uk/products/mud-st...nsole.html
Are there any variations between Tdi/Td5/Puma...etc I should be aware of before I start searching? 1993 200 Tdi 90 CSW 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5117 ![]() ![]() ![]() |
All Defender roofs will fit, sometimes a little bit of effort is needed I have replaced roofs where a few of the bolt holes have not lined up so the odd new hole had to be drilled, but in the whole, all pressing dimension wise are the same from 1984 to the last model. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
Are the 03+ ones a superior design? 1993 200 Tdi 90 CSW
IIRC they are meant to be lighter than the previous two roof designs and the pressed ribs stop the metal from flexing and thrumming at speed.
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1053 ![]() ![]() ![]() |
LAter roofs on Station Wagons are higher due to the new seats.
No, they're not
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The SW with forward facing seats has a higher roof. My old Td5 with side facing seats was lower than my current 110 with forward facing. You can see it's higher at the back. Front is the same.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
What a load of nonsense ![]() |
Sorry, but you're mistaken. The Puma rear seats are let into the wheel arches to accommodate them. The roofs are exactly the same as later TD5's and the same general dimensions as all previous models. Any difference that you've noted will be down to tyres or suspension. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Every roof on a Defender I have worked with has been the same with the exception as already mentioned ribs on early and some late models, however, dimension wise they are exactly the same. I have no idea why the roof mentioned by AMBxx is any different but its a Defender
![]() http://www.youtube.com/user/conwy1 |
Well unless we count commercial Defenders in the South of Ireland that had raised rear roofs to bet export and tax laws
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
One with a roof raised like this?
![]() ![]() Click image to enlarge I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Wrong side of the border
![]() Think they could do with some of them in London now though ![]() Like this: ![]() Click image to enlarge |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3600 ![]() ![]() ![]() |
I would have gladly paid the tax. That really does not look nice.
