Home > Maintenance & Modifications > New owner, New Puma 110, what would you tweek/modify first?
Page 2 of 3 <123>
jst
Waxoyl it and add some soundproofing if there is none in the rear. Then drive it for 6mths without spending anything on upgrades. Your list will change over that 6mth period to what you feel is important. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #730683 23rd Sep 2018 3:18pm
Paulcmccormack
United Kingdom 2010 Defender 110 Puma 2.2 CSW Zambezi Silver
Thanks Edo
Where did you get the double din facial from and is it any good?
Did you fit it yourself and if so was it easyish. Did you need any adapter looms etc...
Fitted one a while back to the first ever LR freelancer, but that was a real sod to get the dash off. I’m hoping the defender will be a bit more basic.
I’m not sure how much the Alpine one is, but it stands out from the dash which may look great or a bit pants. I’m undecided..
It can however have a rear view camera added and has all the fancy maps and air play etc...
But you can get sat nav and a camera in the rear view mirror for a few hundred now.
Post #730713 23rd Sep 2018 6:25pm
Paulcmccormack
Just
I agree, but i’ve seen with defenders that you don’t loose much by playing about and modifying them.
And I like to play. Plus it’ll make it mine....
Post #730715 23rd Sep 2018 6:26pm
Paulcmccormack
Post #730718 23rd Sep 2018 6:39pm
JOW240725
Welcome to Defender ownership and particularly to D2N the place full of help and spending ideas! I will cost you a fortune if you let it! As above security and corrosion protection. Then I suggest you live it then see what needs doing. Whilst adding to the Defender might not depreciate the vehicle you rarely get back what you spend from what I see.
Most of all photos, photos, photos Thumbs Up James
Instagram @suffolk_rovers
Post #730728 23rd Sep 2018 7:09pm
JOW240725
Paulcmccormack wrote:
Anyone tried these?
https://www.exmoortrim.co.uk/puma-premium-upgrade-trim-kit.html
If you're looking to retrim, I highly recommend speaking to Phil Bahfir at OEM Developments. His interiors are top notch and he's a great guy to deal with. You won't know where to stop though.
Re-trim seat kit, padded cubby lid and 4 part dash kit to start.... Whistle James
Post #730729 23rd Sep 2018 7:12pm
Paulcmccormack
Thanks James
That's EXACTLY what I was after. I'll give him a call in the morning.
Superb...
Post #730740 23rd Sep 2018 7:34pm
Paulcmccormack
OK. So so far I have:
A decent immobilizer... Any idea what is best?
Security screws on the doors etc.. (mad, but I understand)
Soundproofing
Rust protection
Protect the mud flaps. (Free-ish, so why not)
Heated seat kit. (for the wifey)
Leather seat kit from OEM.
Cubby box as mine loks like a plastic tray.
Double din stereo or single din upgrade. Maybe a reverse camera added into it.
Hmmm...... interesting and I haven't even picked it up yet. So maybe I will do the security bits. Do the soundprofing myself then wait a bit.
Anything else that is a must, but not thought about?
Post #730748 23rd Sep 2018 7:53pm
edo
Thanks Edo
There are two types. One "flat where you have to cut the existing vents and clock off (bad), and one full.
I got mine from Mud.co.uk. In hindsight I wish I had gone for matt rather than gloss as the finish is a bit prone to scratches.
Cutting the hole for the relocation panel is a bit worrying and most have a 52mm round slot for a gauge I would prefer not to have.
I also had to extend 3 switches to make them reach the relocation panel, but its all doable if you take your time.
Post #730769 23rd Sep 2018 9:24pm
Paulcmccormack
Cheers Edo
Was looking at the demon earlier.
https://www.mudstuff.co.uk/catalogsearch/result/?q=Console
I assume you went for the £250 as it’s a bit easier, but scratches. There is no mat option as a full Facia so I assume this is what you mean about cutting the other one in two.
Is this the best option????!
Paul
Post #730776 23rd Sep 2018 10:20pm
edo
Yup some are like this:
http://www.landroverweb.com/landrover/wp-c...24x768.jpg
Which you dont want as you have to cut off vent and clock section which is not something you want to be doing!
Post #730809 24th Sep 2018 7:52am
Plantagenet
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
I echo JST's comments.
I bough my TDCI 110 in 2014 and spent the few weeks thinking what to upgrade. I decided to sound-proof it (via CSK) and have it waxoyled and then live with it before spending anything else.
4 years on and I've spent nothing else since and am completely happy with the truck!
James
Post #730815 24th Sep 2018 8:14am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
You can always paint the double din fascia to match the vehicle. I also cut the 52mm circle section off the relocation panel and smoothed the corners out. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #730819 24th Sep 2018 8:32am
MartinK
Anyone tried these?
Suggest having a look at LRI as well: https://www.lrisolutions.co.uk/products/de...tml#page=1
Discount code here: http://www.defender2.net/forum/topic48881.html
I stayed with original seats, all 5 re-covered in good quality leather:
 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #730822 24th Sep 2018 9:08am
Paulcmccormack
HI Martin
I have a price for these covers but they are unfortunately a lot more expensice compared to the ones on OEM supplies. As I've 7 seats it gets silly. Even with the discount. But probably great quality if I could afford it.
Roy
That looks mint... Where did you get the bits from?
Paul
Post #730883 24th Sep 2018 2:47pm
Page 2 of 3 <123>
