Home > Technical > Front Shock Removal 2014 puma
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
I’m curious what the best practice is for removal of the front shocks on the 2014 puma. Appears the top of the shock towers have a cover on them in the engine bay. Best to just remove the covers to access the top bolt? It also looks like you could perhaps access it from the wheel arch but not much room.
Post #729539 17th Sep 2018 2:53pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Take the covers off. Undo the nut on the bottom of the shock. Undo the four 13mm nuts holding the turret to the chassis. Next just pull the turret and shock up through the inner wing where you've just taken the covers off. Easy job 10-15mins. Thumbs Up
Post #729556 17th Sep 2018 4:24pm
big110
Wow! Me thinks this is so much better than dropping axle, pulling springs out and everything! Thank you mate!
Post #729558 17th Sep 2018 4:30pm
Do soak those turret bolts in penetrating fluid I.e. WD40 the day before and clean the threads.
And go easy undoing them as they are prone to snap the studs off!
They also have a torque in the WSM to be tightened to.
Unless they are really old you shouldn't have a problem.
Tightening the top mount is not so straight forward though. $W33T $0U7H3RN $UG4R
Post #729567 17th Sep 2018 5:27pm
big110
What’s the tq required??
Also, what’s special about the top mount on the shock?
Post #729569 17th Sep 2018 5:36pm
14NM.
This thread maybe of interest:
http://www.defender2.net/forum/topic16066....ing+torque $W33T $0U7H3RN $UG4R
Post #729575 17th Sep 2018 5:52pm
big110
Thx for that, steve!
Post #729579 17th Sep 2018 6:10pm
williamthedog
The springs stay there if you're only replacing the shocks. No need to jack up or anything else. Springs are easy enough to change as well. Thumbs Up
Post #729587 17th Sep 2018 6:22pm
Biffas
England 2014 Defender 110 Puma 2.2 USW Corris Grey
On a puma on the n/s you need to carefully move coolant hose out of the way and on the o/s you need to move air intake.
Post #729598 17th Sep 2018 6:55pm
NickMc
Buy a spare set of turret rings and nuts before you start as it’s wet likely you’ll break at least one.
Post #729841 18th Sep 2018 9:01pm
