Home > Puma (Tdci) > 52 mm OBD2 Gauge
Bergos
Portugal 2007 Defender 110 Puma 2.4 HT Keswick Green
52 mm OBD2 Gauge
Hi,
I would like to install a 52 mm gauge to monitor (mainly) my Cylinder Head Temperature. One I can just connect to the OBD2 plug.
Right now I use Nanocom but I would like something permanent, integrated into the dashboard in a nice way.
Can you recommend something?
Has maybe anyone tried this one:
https://www.amazon.co.uk/Autool-Pressure-O...07BF568WW/
??? Bergos
LR Defender 110 HT 2007 (2.4 Puma)
https://www.facebook.com/LR.Wanderlust/
Post #728648 12th Sep 2018 5:41pm
Bluest
I don’t know if it displays what you want, but you won’t get more integrated than this.
eBay Item No. 162687467417 2007 110 TDCi Station Wagon XS
Post #728649 12th Sep 2018 5:48pm
grafty99
I have seen one installed in a 2.2 puma. Looked ace Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #728651 12th Sep 2018 5:59pm
Bergos
https://rover.ebay.com/rover/0/0/0?mpre=ht...2687467417
The price is absurd! Bergos
Post #728654 12th Sep 2018 6:05pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Fit an ultragauge in your clocks. Being a 2.4 you have no DPF warning lights to move either. You’ll be able to monitor much more than cylinder head temperature then.
 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #728694 12th Sep 2018 9:41pm
Roy5695
Cylinder head temperature top right on my screen. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #728695 12th Sep 2018 9:41pm
Cupboard
Does the Ultragauge measure the level of the tank in a 2.2? In my 2.4 it can't so it has to guess based on your driving and it's not very accurate.
Post #728719 13th Sep 2018 7:27am
Roy5695
It sort of guesses. But is pretty accurate, you need to calibrate the fuel usage over a period of time and then it works quite well. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #728723 13th Sep 2018 7:34am
dorsetsmith
fuel level go too instrument cluster gauge only and not the ecm the only fuel input to the ecm is low fuel
Post #728724 13th Sep 2018 7:41am
Martin
Site Admin
The gauges publish the fuel level on CAN for the ECM to read Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #728732 13th Sep 2018 9:02am
dorsetsmith
R right must be problem Exclamation with instrument cluster thank god is not mine Laughing
Post #728733 13th Sep 2018 9:31am
edo
I'd like something like this to go in the spare 52mm hole I have in the switch relocation panel from double din conversion.
As little messing with wiring as possible, I'm all done with wiring, it's a miracle there wasnt a fire.....
Post #729559 17th Sep 2018 4:35pm
edo
Post #729958 19th Sep 2018 6:46pm
sloderby1
From that listing:
Quote:
*Not suitable for cars before 2005 or vehicles where the OBD is constant 12v
Odd because the requirement for OBD connectors is that the battery (12V) connection MUST be constant (not ignition switched)
Post #729960 19th Sep 2018 6:55pm
edo
yup, not sure about that!
Post #729961 19th Sep 2018 6:57pm
