![]() | Home > Puma (Tdci) > 52 mm OBD2 Gauge |
Bergos Member Since: 08 Aug 2015 Location: Somewhere in Portugal Posts: 95 ![]() ![]() ![]() |
Hi,
I would like to install a 52 mm gauge to monitor (mainly) my Cylinder Head Temperature. One I can just connect to the OBD2 plug. Right now I use Nanocom but I would like something permanent, integrated into the dashboard in a nice way. Can you recommend something? Has maybe anyone tried this one: https://www.amazon.co.uk/Autool-Pressure-O...07BF568WW/ ![]() Click image to enlarge ??? Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
I don’t know if it displays what you want, but you won’t get more integrated than this.
eBay Item No. 162687467417 2007 110 TDCi Station Wagon XS |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
I have seen one installed in a 2.2 puma. Looked ace
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
The price is absurd! Bergos LR Defender 110 HT 2007 (2.4 Puma) https://www.facebook.com/LR.Wanderlust/ |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Fit an ultragauge in your clocks. Being a 2.4 you have no DPF warning lights to move either. You’ll be able to monitor much more than cylinder head temperature then.
![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Cylinder head temperature top right on my screen. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Does the Ultragauge measure the level of the tank in a 2.2? In my 2.4 it can't so it has to guess based on your driving and it's not very accurate.
It sort of guesses. But is pretty accurate, you need to calibrate the fuel usage over a period of time and then it works quite well. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
fuel level go too instrument cluster gauge only and not the ecm the only fuel input to the ecm is low fuel
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
The gauges publish the fuel level on CAN for the ECM to read
R right must be problem
edo Member Since: 20 Aug 2018 Location: Devon Posts: 379 ![]() ![]() |
This looks ok value?
https://www.ebay.co.uk/itm/Prosport-4-in-1...Sw3gJZFaPu |
sloderby1 Member Since: 08 Feb 2018 Location: Derby Posts: 20 ![]() |
From that listing:
Odd because the requirement for OBD connectors is that the battery (12V) connection MUST be constant (not ignition switched) |
yup, not sure about that!
