Home > Maintenance & Modifications > Spraying log sliders
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
I want to paint the sliders so was intent on removing them, quick rub down, undercoat and a can of top coat gloss spray. Is it as simple as that or do I need special spray? What should I do with the surface rust...will it need treating? Thanks for any tips.
Post #728135 9th Sep 2018 7:03pm
Bluest
Are we talking about rock/tree sliders? If so they are probably powder coated, which makes a DIY repair tricky. Powder coat is horrible stuff to remove. What sort of condition are they in? If it is powder coat, they’d likely need stripping or blasting really to get a lasting repair done. I understand you can burn it off too.
However, if they are wet painted and not too bad, you can do what you suggest. 2007 110 TDCi Station Wagon XS
Post #728155 9th Sep 2018 7:39pm
Alex1976
If you are restarting them then I would recommended truck bed liner spray - much tougher for this kind of application.
Post #728170 9th Sep 2018 8:22pm
JOW240725
Speak to Buzzweld they do a huge range of products. Probably suggest RCP rust killing primer followed by Raptor, but speak to them they're the experts. James
Instagram @suffolk_rovers
Post #728180 9th Sep 2018 8:43pm
zsd-puma
If they're powder coated, go over them with a flap wheel in a grinder. That'll remove and loose stuff and rust and rough up any sound powder coat. Then you can spray them up with stone chip and a Shultz gun, it gives a textured finish so hides all the imperfections. If you want it glossy then you can go over the stone chip with a gloss paint in what ever colour you like.
Post #728192 9th Sep 2018 9:35pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I raptored mine but I think I under estimated how tough the powdercoating was, I should've keyed it with lower grit/rougher sandpaper as so has flaked off, only few&small patches... i'm waiting for a warm day and ill tidy it up. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #728326 10th Sep 2018 5:42pm
