![]() | Home > Maintenance & Modifications > Spraying log sliders |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
Are we talking about rock/tree sliders? If so they are probably powder coated, which makes a DIY repair tricky. Powder coat is horrible stuff to remove. What sort of condition are they in? If it is powder coat, they’d likely need stripping or blasting really to get a lasting repair done. I understand you can burn it off too.
However, if they are wet painted and not too bad, you can do what you suggest. 2007 110 TDCi Station Wagon XS |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 ![]() ![]() |
If you are restarting them then I would recommended truck bed liner spray - much tougher for this kind of application.
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Speak to Buzzweld they do a huge range of products. Probably suggest RCP rust killing primer followed by Raptor, but speak to them they're the experts. James
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
If they're powder coated, go over them with a flap wheel in a grinder. That'll remove and loose stuff and rust and rough up any sound powder coat. Then you can spray them up with stone chip and a Shultz gun, it gives a textured finish so hides all the imperfections. If you want it glossy then you can go over the stone chip with a gloss paint in what ever colour you like.
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I raptored mine but I think I under estimated how tough the powdercoating was, I should've keyed it with lower grit/rougher sandpaper as so has flaked off, only few&small patches... i'm waiting for a warm day and ill tidy it up. 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
