Home > Maintenance & Modifications > Snorkel benefits?
Co1
Snorkel benefits?
Finally bought my defender and it has a snorkel fitted. I’m not a huge fan, but apart from the obvious when it comes to water ingress, are there any other advantages? I won’t be wading though more than 12” of water so don’t need it for that element, so just deciding whether to take it off.
Post #726765 2nd Sep 2018 1:36pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
You have to seal all of the intake system before it's a snorkel. What you have at the moment is a raised air intake. Ok it's taking air from where there's less dust etc. They do have a impact on performance so it's your choice. Thumbs Up
Post #726767 2nd Sep 2018 1:55pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Also worth remembering that you will have extra holes to fill and spray, and possible damage to the wing!
Post #726770 2nd Sep 2018 2:00pm
Co1
Re: Snorkel benefits?
Thanks. I take it you mean a negative impact on performance?
Post #726771 2nd Sep 2018 2:01pm
Co1
Yep, I had considered that, which will be a pain! This is why I am balancing up the benefits of just leaving it on.
Post #726772 2nd Sep 2018 2:02pm
Swac3
Check your insurers, my old one refused to insure ours, I phoned for a simple change of vehicle and had my insurance cancelled. 3 Landrovers
Post #726780 2nd Sep 2018 3:11pm
JOW240725
BAS did some tests and proved the intake does restrict airflow, so unless you need it or particularly like it, I'd take it off. Thumbs Up Nice 90! Thumbs Up James
Instagram @suffolk_rovers
Post #726833 2nd Sep 2018 8:05pm
Co1
Thanks and thanks JOW!
Post #726835 2nd Sep 2018 8:06pm
If you remove the rain separator and do the airbox mod though the results are borderline differences. Idea
Horses for courses really in my view, I am however not a fan of RAI's as they have in my point little purpose.
A Snorkel even if not used as designed which very few will is sealable and as such fit for purpose.
Mine is sealed except for the airbox base drain hole, which A, I could seal if needed. B, is a good drain exit point.
I could seal it entirely but personally I'd rather have a drain point present than none in case of atmosphere fluid ingress.
You could use a rubber plug too I guess, which would be easy in and out but let's face it how many Puma owners wade that deep! TheThunder Rolls🇬🇧🇺🇸
Post #726837 2nd Sep 2018 8:15pm
williamthedog
If you remove the water separator in the airbox it near enough cancels out the snorkels restriction. Thumbs Up
Post #726838 2nd Sep 2018 8:16pm
Co1
Thanks William, I’ll look at hat first!
Post #726842 2nd Sep 2018 8:21pm
Co1
Thanks Steve, I appreciate the time taken for that level of detail.
Post #726843 2nd Sep 2018 8:22pm
zsd-puma
It depends how you word it. That's a genuine Land Rover one, and probably been fitted from new. In which case you wont need to tell your insurer as it's considered standard. The question you have to ask them is "do you need to know about manufacturer fitted accessories?" every insurer I've ever spoken to says no.
Post #726861 2nd Sep 2018 9:14pm
zsd-puma
In terms of real world performance though it's not noticeable having one fitted. - I know because I fitted one, and saw no difference in performance or fuel economy.
About the only thing they'll do is help keep a bit of dust out of your air filter, theoretically it will keep the air filter cleaner for longer which will improve performance in the long term - but again I doubt this would actually be noticeable.
One potential benefit to them, is if you fit a light bar, either on a roof rack or a stand alone one, it gives you somewhere convenient to route the cables down to the engine bay without drilling holes in the roof.
Post #726863 2nd Sep 2018 9:18pm
Maxxed_Ross
Scotland 2001 Defender 90 Td5 CSW Cobar Blue
Not always. I had this issue with my Tomb Raider as it had the optional "Extreme" pack which included a Mantec snorkel from the factory.
The insurance took the stance that if it was factory fitted then it was fine, but if it was an optional extra then my insurance would be cancelled. Luckily whoever wrote the Wikipedia page wrongly said it was standard Laughing
Oh and that was Adrian Flux, the so called modified specialists Evil or Very Mad 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320
Post #726869 2nd Sep 2018 10:02pm
