Home > Puma (Tdci) > Wipers have stopped at half way
Eyezy
New Zealand 2008 Defender 90 Puma 2.4 HT Alaska White
The wipers have stopped half way up the screen, I can hear what I think is a relay clicking once when they are switched on and when switched to intermittent I think I can hear a relay clicking every few seconds. I can't hear the wiper motor running. The washers also work when the button is pressed. Can I assume that means the switch is OK, the fuse appears to be OK. Would i be able to hear the wiper motor running if it's the cable drive? Does this point to a motor fault ? It's a 2008 90 that's done 100k kms. Thanx
Post #726696 1st Sep 2018 7:50pm
It could be the park switch.
But first lube the spindles and give the arms a little push whilst switched on $W33T $0U7H3RN $UG4R
Post #726702 1st Sep 2018 8:19pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Probably the spindles as said above, if you're lucky you might be able to oil them to get them working. If not get ready for cursing. Confused
Post #726718 1st Sep 2018 9:23pm
Eyezy
Outstanding ! - A couple of squirts of WD40 and we are all set to enjoy another sunny day in Auckland
Thanx Bow down
Post #726721 1st Sep 2018 10:37pm
Thumbs Up Thumbs Up
Use a bit of s longer lasting oil in there too shortly, as the WD40 will dry up but is good for freeing them up. $W33T $0U7H3RN $UG4R
Post #726758 2nd Sep 2018 12:43pm
williamthedog
I use acf 50 on mine. A few drops every couple of months and you should be ok Thumbs Up
Post #726768 2nd Sep 2018 1:56pm
Same here now too. Thumbs Up $W33T $0U7H3RN $UG4R
Post #726783 2nd Sep 2018 3:18pm
Eyezy
Will do - Thanx for the tip
Post #726790 2nd Sep 2018 3:42pm
GrouseII
United Kingdom 2008 Defender 90 Puma 2.4 HT Coniston Green
I had the same issue and the relief was great when good ol WD40 solved it ... BUT, I continued to repeat the process of running the wipers (pulled away from screen) and squirting liberally for a few minutes on the splines for at least 4 days to make sure the oil got down good and deep and did it s job. Each time some rusty residue came out of the splines.
Besides, i love the smell of WD40 Very Happy
Post #727529 6th Sep 2018 11:26am
