Home > Puma (Tdci) > Wipers have stopped at half way |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 |
It could be the park switch.
But first lube the spindles and give the arms a little push whilst switched on Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
1st Sep 2018 8:19pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Probably the spindles as said above, if you're lucky you might be able to oil them to get them working. If not get ready for cursing.
1st Sep 2018 9:23pm |
Eyezy Member Since: 07 Jul 2017 Location: Auckland Posts: 4 |
Outstanding ! - A couple of squirts of WD40 and we are all set to enjoy another sunny day in Auckland
Thanx |
1st Sep 2018 10:37pm |
Use a bit of s longer lasting oil in there too shortly, as the WD40 will dry up but is good for freeing them up. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
2nd Sep 2018 12:43pm |
I use acf 50 on mine. A few drops every couple of months and you should be ok
2nd Sep 2018 1:56pm |
Same here now too. Play Stupid Games, Win Stupid Prizes.
2nd Sep 2018 3:18pm |
Will do - Thanx for the tip
2nd Sep 2018 3:42pm |
GrouseII Member Since: 29 Dec 2017 Location: Bucks Posts: 37 |
I had the same issue and the relief was great when good ol WD40 solved it ... BUT, I continued to repeat the process of running the wipers (pulled away from screen) and squirting liberally for a few minutes on the splines for at least 4 days to make sure the oil got down good and deep and did it s job. Each time some rusty residue came out of the splines.
Besides, i love the smell of WD40 |
6th Sep 2018 11:26am |
