Home > 130 > 130 rear arches |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 337 |
I think opinions on this vary, but IIRC I have 110 fronts on mine, reversed, and attached using 14 mm rivets. I used a cutting disk on an angle grinder to cut them back a bit (using tape as a guide), then sanded for a smooth finish.
Click image to enlarge Defender 130 HCPU Td5 MY2000 |
26th Aug 2018 5:18pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
I've done a few, use standard rears. They are not quite the correct shape however when you fit them if you warm them up with something like a space heater this will help. Use molegrips to hold the arch in place whilst fitting. I use 16mm rivets.
Take a look in my gallery's. Click image to enlarge Click image to enlarge 130's have feeling's as well you know |
26th Aug 2018 8:07pm |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
use a heat gun and be patient.
i used normal 110 rear arches and instead of rivets i used threaded nutserts |
27th Aug 2018 1:36pm |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 |
Thank you all for your replies.
I've ordered set of rears and rivets and will have a go at the weekend, I shall put some pictures up when I'm done. Ronald |
27th Aug 2018 8:02pm |
Click image to enlarge Finally got around to fitting my rear arches. Got a nice picture today on the way to St Michael's Mount |
28th Sep 2018 3:53pm |
Wider britpart arches
Click image to enlarge Click image to enlarge up front |
28th Sep 2018 4:51pm |
Naf what size type do you have. I'm running on 235's
28th Sep 2018 5:15pm |
Wheels are 20x9 with an et10 am also runnin a 30mm spacer
Tires are 305/50r20 nitto grapplers |
28th Sep 2018 5:41pm |
saroshadil Member Since: 29 Nov 2018 Location: Detroit, Michigan Posts: 3 |
These are my favorite. Can you please post some more photos!
20th Mar 2019 9:29pm |
Thanks! I will try to (remember to) take some more and post them here. Defender 130 HCPU Td5 MY2000
21st Mar 2019 9:52am |
Here ya go!
Stock suspension and 285x75r16... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Defender 130 HCPU Td5 MY2000 |
21st Mar 2019 6:36pm |
