Home > Puma (Tdci) > Engineering project to reduce weight in a 110
Matt3932
I'm curious, and I've a little time on my hands, so, I'd like to see how much weight can be removed from my 110 without compromising the on and off road capabilities of the vehicle. Conscious that rotating mass is a significant issue, I've fitted Bowler wheels, I've also looked at:
CF panels (ridiculously expensive)
Fibreglass panels (relatively fragile)
Other Bowler parts (v pretty but v expensive)
In terms of removing stuff, the tow bar could come off (IRO 11kgs?)
The front bumper could be drilled (IRO 2kgs)
Standard puma seats could be changed out for lighter items (IRO 10kgs?)
But these are incremental savings - what are the big ticket items, it has to come down to chassis and axles I'd imagine....I'd appreciate any thoughts/lessons learned before I embark on a series of costly follies!
Post #724097 18th Aug 2018 11:49am
AMBxx
Open top?
Post #724102 18th Aug 2018 12:02pm
Matt3932
Already taken the roof off!
Post #724104 18th Aug 2018 12:06pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
Defenders are NOT really heavy imo V8 90...WIP
Post #724107 18th Aug 2018 12:29pm
Matt3932
Granted, all things are relative. Challenger 2 's are really heavy. However, I don't have one of those. I have a Defender!
Post #724110 18th Aug 2018 12:46pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Why buy a defender then worry about how much it weighs? It does fairly well as it is.
Post #724122 18th Aug 2018 2:27pm
Matt3932
I'm not worried. I'm curious. I'd imagined the envelope has been pushed by the dedicated off road fraternity, and the Wildcat and it's ilk demonstrate what's possible with factory standard engineering. I'd like to know what can be achieved without significant expenditure
Post #724123 18th Aug 2018 2:37pm
Harry.O
You could swap the glass for polycarbonate, swap doors for 2 piece doors, remove any rubber mats, remove any unnecessary seats, ditch the spare wheel and use a TD5 bonnet. Swapping out the cast radius arms to the aftermarket stuff would definitely lose some weight. If using a drop down tailgate you could make a lighter version from alloy and depending on how far you intend to travel, don't brim the fuel tank.
All of the above is fairly cheap to do and not too difficult Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #724129 18th Aug 2018 3:52pm
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Buy a 90?
Post #724131 18th Aug 2018 4:10pm
Mountain_man
Wales
if it is a pre puma one then an alloy bonnet with most of the strengthening frame removed. The inner wings are pretty meaty to and could be substituted easily enough with glass fibre copies. If you are serious about losing weight then bang in an SD1 gearbox and go rear wheel drive only Smile
Post #724132 18th Aug 2018 4:11pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
What a strange subject, I guess wheels and tubular chassis are your best bet 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #724139 18th Aug 2018 4:49pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Diesel engines are heavy. Change it for a lighter petrol one.
Lightened flywheel, lighter handbrake drum (they are stupidly heavy) remove any engine, steering guards etc. Remove any emmisions stuff and std exhaust for a lightweight system
Get rid of any comforts. Radio heater dash. Think comp safari!! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #724147 18th Aug 2018 5:43pm
zsd-puma
There isn't really much factory engineering left in a Bowler Wildcat, they're basically a new car with a few Defender bits and designed to look a bit like a Defender.
On puma's and late TD5's the door skins are steel, you could replace them with the earlier ally ones. Or you could just remove them all along with the roof and windscreen. So it somewhat resembles an US army recon version - how far do you want to go?
You could strip out all the sound insulation, carpets, head lining etc.
Seats could probably be replaced with Series 3 ones. Dash could probably be replaced with some simple brackets.
But as you've alluded to the vast majority of the weight is going to be in the chassis and drive train, most of which is difficult if not impossible to lighten.
Lightening a Defender is a bit like buying a Ferrari and making it suitable for doing parcel deliveries.
Perhaps you could delete your duplicate post in the Maintenance and Modifications section?
Post #724155 18th Aug 2018 6:48pm
Kit
Yeah the Wildcat is a fully tubular chassis with independant suspension, the Tomcat is based on a LR chassis with a tubular frame welded onto it 1993 200 Tdi 90 CSW
Post #724176 18th Aug 2018 9:31pm
Engineering project to reduce weight strength in a 110
Utterly pointless exercise in my opinion. Nothing you can realistically do will make any significant difference to the weight, and it won't have any effect on any aspect of performance except strength and longevity.
What are you actually trying to achieve?
Post #724178 18th Aug 2018 9:49pm
