Home > Maintenance & Modifications > Home made transmission oil filler
Siwynne
Last time I changed all fluids I found it hard to fill transfer and from below. I set about collecting the necessary to make a pressurised filler. I scrounged a pressure cooker and some other bits of pipe and a tyre valve. After drilling some holes in the lid I fitted the valve and feed pipe. Tested and works a treat. Simply put the correct volume of oil in the pan and blow into the correct hole on the truck.
Post #723235 13th Aug 2018 4:08pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Laughing love it! Bow down 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #723238 13th Aug 2018 4:12pm
gilarion
So do I Thumbs Up Ingenuity at its best. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #723240 13th Aug 2018 4:19pm
zsd-puma
well it's clever, and probably easier than an oil syringe. but I can't help thinking just using a garden sprayer with the end chopped off the pipe would do the same thing.
https://www.screwfix.com/p/sx-cs5-white-bl...0wod41AE-A
Post #723339 14th Aug 2018 12:38am
ian series 1
Overall you will find it hard to beat one of these,
Makes filling diffs and boxes effortless.
Wouldn’t be without mine,
but 10/10 for the pressure cooker idea Laughing
 80" 80" 86" 88" 90"
Post #723355 14th Aug 2018 7:11am
Siwynne
Garden sprayer works. I enjoy making stuff and this cost me nowt as I scrounged the pan and had all the other bits. That Castro’s pump is a great looking bit of kit.
Post #723368 14th Aug 2018 8:55am
Caterham
do you have to put the pressure cooker onto a pre-heated stove for it to work?
Post #723380 14th Aug 2018 9:37am
I guess it would thin the oil and make it easier to transfer!
You could bung some chips in the leftover too.
Post #723410 14th Aug 2018 12:12pm
^^^^ Rolling with laughter WeWillWin🇬🇧🇺🇸
Post #723417 14th Aug 2018 1:09pm
williamthedog
2011 Defender 90 Puma 2.4 PU Tamar Blue
Only if it was high in polyunsaturated fat and low in saturated fat though Rolling with laughter Rolling with laughter Rolling with laughter
Post #723428 14th Aug 2018 2:14pm
