Home > Wheels & Tyres > New boots
gcc130
New boots
I run a 2.4 tdci 130 on Michelin xzl’s, usually getting around 20k miles on a set of tyres.
It’s time to replace them again and I’m considering my options.
I like the tall , narrow xzl’s so I could just replace with the same or I could go for Goodyear Wrangler MT/Rs which I ran on my previous Td5 130.
What is the nearest size to 7.50 I can use on my tubeless wolf rims? I don’t want anything too wide.
It’s a working vehicle, towing everyday, often off road.
Cheers, Andrew
Post #722750 10th Aug 2018 7:58pm
stanstorey
235 85 16 Thumbs Up
Post #722791 11th Aug 2018 7:33am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Re: New boots
255/85/16
Toyo Open Country M/T 255/85-16 on Wolf
 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #722808 11th Aug 2018 8:56am
As stanstorey says, 235/85 is the factory equivalent of 7.50. Darren
Post #722813 11th Aug 2018 9:28am
Theater
Yes !
Of course ! Marco
Post #722821 11th Aug 2018 10:32am
gcc130
Thanks guys, just need to shop around now.
Post #722842 11th Aug 2018 12:11pm
Retroanaconda
20k is a very poor lifetime for a set of tyres on a Land Rover.
I would suggest BFGoodrich All Terrain in 235/85/R16 - good all rounder and I got 72k out of my last set so good value too. Or if you need to do lots of work in wet mud then the equivalent BFGoodrich Mud Terrain would work, at the cost of some economy and noise.
Post #722849 11th Aug 2018 1:04pm
I would mirror the above, I'd rather pay a touch more on fuel than tyre's all the time.
I found with narrower MUDs the shoulders wear quite a bit too, with road use which we all would be using pretty much. KEEP CALM AND Drill ON
Post #722851 11th Aug 2018 1:07pm
VVS210
Have you missed the bit where the OP says he is running Michelin XZLs??? - they are not exactly road tyres... comparing them to, or suggesting as an alternative, BFG A/Ts is a bit like comparing rugby with football Whistle
As it happens I have a set of 235/85/16 XZLs for serious winter use off road & a set of 235/85/16 BFG A/Ts for the rest of the year so know a little bit about both tyres Wink
That said, I would agree that if you want good off road tyres that also behave on the road then BFG M/Ts would be a sensible consideration Thumbs Up
Post #722860 11th Aug 2018 2:37pm
gcc130
I think I will end up going for a set of Wrangler MT/Rs at £132 a corner inc vat + fitting.
I would love to get 72k from a set of tyres but I think it unlikely. The 130 is a heavy vehicle and we carry about 1/2t of kit in the back as well as towing up to 3.5 t daily, mostly A roads but often motorway and off road.
I am disappointed with the rate of wear of the xzl’s but have been pleased with them in other respects, as with most things it’s all about compromise 😊
Post #722910 11th Aug 2018 7:04pm
Retroanaconda
I based my recommendations on what his stated use of the vehicle was, not on a presumption that the existing fitment was appropriate Rolling Eyes
Post #722913 11th Aug 2018 7:18pm
