Home > Maintenance & Modifications > Backlash sorted |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 |
That 'real' DCPU has made an appearance again. I'm not going to forgive or forget what you said Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
11th Aug 2018 11:08am |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
11th Aug 2018 7:31pm |
There can be a transmission "clunk" as the clutch engages and the splines on the half shaft rotate slightly in the drive flange. If you remove the rubber cap you can see if there is grease lubricating the half shaft, mechanics who know Defenders will grease at every service thus prolonging their life. Welding the shaft to the flange creates a one piece half shaft eliminating another transmission wear point. |
11th Aug 2018 7:51pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
Mine has recently developed a lovely clunk from the back.
If I try and drive with the handbrake on it doesn't clunk, but if I let the handbrake off and stand on the normal brakes it clunks horribly, once every time you take up drive after changing from reverse to forwards and back. It's almost like someone's strapped a cow bell underneath. |
11th Aug 2018 9:32pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 671 |
Fitting the single piece rear drive shafts to my 110 made a huge difference to backlash and how it drives.
12th Aug 2018 7:07am |
Quick update
After 1k miles of motorway, B road and unpaved road driving the Defender feels tighter and smoother. I've never driven a Land Rover (owned 2xSeries, RRC, 110 300tdi) with virtually no backlash before. even this 2011 110USW that had 40k on the clock when I bought it, and it's a revelation! At very low speed on unpaved roads in the Dales it was more comfortable and generally easier to control through technical sections. On the motorway it seemed more planted and smoother. |
21st Aug 2018 2:32pm |
