Home > Maintenance & Modifications > Swing away Spare Wheel Carrier suggestions |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Pfft, all this work with this temperature will cost you a beer!
Anyway, here you are. By the way, I think may be it is possible to fit the carrier somewhat more to the left, further away from the edge if that is want you want? Click image to enlarge Oh, and those are cm, not inches... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
2nd Aug 2018 4:45pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Yes it is possible to get the wheel shifted by up to 90 mm to the left and this might satisfy OCDness for being central.
However likes many things in life it is a compromise. Shift spare wheel 90 mm to the left and it is more difficult to access the rear door lever. Brendan |
2nd Aug 2018 5:31pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Haha I hear you, I guess it should be no worse than the standard wheel carrier position and access to door handle is ok.
2nd Aug 2018 5:35pm |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 173 |
i see there are already some pics been posted i have taken some so i will post them anyway.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge you can see in the second pic i cut a piece of 2mm aluminium to space the bottom bracket out the same as the body work and in the third pic i made a couple of pieces rubber to hold the bracket of the back door and some plastic washers to take up the space on the bracket fitted to the back door, i also had to space out the rubber stops that were barely touching the carrier itself. nobody is perfect but being Scottish is a start |
2nd Aug 2018 6:36pm |
