Home > Maintenance & Modifications > Swing away Spare Wheel Carrier suggestions
Page 2 of 2 <12
VeeTee
Netherlands
Pfft, all this work with this temperature will cost you a beer! Whistle Rolling with laughter
Anyway, here you are. By the way, I think may be it is possible to fit the carrier somewhat more to the left, further away from the edge if that is want you want?
Oh, and those are cm, not inches... Rolling with laughter Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #721096 2nd Aug 2018 4:45pm
Djcla
perfect thank you , yes ive been in touch with Safari equip and the chap said he could make it so it sits 90mm further to the left which should make it look more central.
Post #721100 2nd Aug 2018 5:12pm
leeds
Yes it is possible to get the wheel shifted by up to 90 mm to the left and this might satisfy OCDness for being central.
However likes many things in life it is a compromise. Shift spare wheel 90 mm to the left and it is more difficult to access the rear door lever.
Brendan
Post #721102 2nd Aug 2018 5:31pm
Djcla
Haha I hear you, I guess it should be no worse than the standard wheel carrier position and access to door handle is ok.
Post #721103 2nd Aug 2018 5:35pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
i see there are already some pics been posted i have taken some so i will post them anyway.
you can see in the second pic i cut a piece of 2mm aluminium to space the bottom bracket out the same as the body work and in the third pic i made a couple of pieces rubber to hold the bracket of the back door and some plastic washers to take up the space on the bracket fitted to the back door, i also had to space out the rubber stops that were barely touching the carrier itself. nobody is perfect but being Scottish is a start
Post #721113 2nd Aug 2018 6:36pm
Page 2 of 2 <12
