Home > Td5 > Metallic sounds when shutting off engine then pully failure |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 |
Is this a common problem?
I was getting a metallic sound when turning off the engine. Then three days later one of the pulleys seized and actually snapped the bolt. This caused the belt to come off. Luckily I had my mad man gauge and noticed the coolant temperature rising significantly. Turn off the engine and rolled The truck out of the woods and onto the road. Pics are below. Click image to enlarge Click image to enlarge Click image to enlarge 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
26th Jul 2018 3:27pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Yes quite common, although I’ve only ever seem to have done them on Discos,
Did your rad survive? The last one I did went on the motorway, made a right old mess! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
26th Jul 2018 6:36pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2108 |
Hope you get it sorted
I must stop reading these threads. I just fitted my new drive belt as part of my annual self-service. It was actually the last item after all the fluids, filters and cleaning the sensors etc. And now... The automatic tension has just given up! I suspect that with me pulling it back to its full tension to fit the belt then it's thrown its hand in. Better on the drive than on the move Just ordered a genuine LR for reliability and longevity. Fingers crossed |
27th Jul 2018 2:49pm |
