![]() | Home > In Car Electronics > Quiet rear speakers? |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Mine has got a factory fitted Alpine head and works fine at rear.
Not aware of this being a problem inherent with the wiring. Have you checked connections at rear of your head unit. |
If there is sound coming out of them then its a problem with the head unit. Ray
hotbadger Member Since: 20 Jul 2018 Location: St Albans Posts: 2 ![]() ![]() ![]() |
that's what I feared. Adding a sub next week and changing front speakers so will examine the wiring first, otherwise may have to change the head unit which is a bit annoying as it a decent double din alpine full screen that came with the car. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20637 ![]() ![]() |
Check your fader on your HU is balanced 50/50 front and rear. ๐๐ป (You May have already already done so. TheThunder Rolls๐ฌ๐ง๐บ๐ธ
โฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
Had a similar problem when my Alpine head unit died and I swapped to a Pioneer head unit.
Still havenโt solved the problem, apart from using my sons mega boom ![]() |
DefenderSmith Member Since: 16 Apr 2018 Location: Essex Posts: 10 ![]() ![]() |
I have the same issue with focal speakers in the rear. Can hear a little bit of sound so know the wires are connected but very quiet.
Mine is powered by a single DIN pioneer head unit. |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
A bit of a random one. But how are you playing the music? I had a aux cable from my phone which was faulty and caused mine. It wasn't till I put a CD in it which I hadn't done in months and all speakers worked fine I realised 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
