Home > In Car Electronics > Quiet rear speakers?
hotbadger
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Santorini Black
My defender has an aftermarket alpine head unit with all the stock speakers.
The rear speakers are almost silent even with the fade right to the rear.
I recently replaced them with aftermarket Focal PC100 speakers and they are still very very quiet.
Should I run new cables to the rear or is this a known problem with a fix? assume the stock wiring must be crap or something as an aftermarket head unit with decent power and aftermarket speakers should surely achieve normal volumes?
Thanks for any advice...
Post #718697 20th Jul 2018 9:10am
Balvaig
Mine has got a factory fitted Alpine head and works fine at rear.
Not aware of this being a problem inherent with the wiring.
Have you checked connections at rear of your head unit.
Post #718702 20th Jul 2018 10:05am
mk1collector
If there is sound coming out of them then its a problem with the head unit. Ray
My build thread
Post #718705 20th Jul 2018 10:15am
hotbadger
that's what I feared.
Adding a sub next week and changing front speakers so will examine the wiring first, otherwise may have to change the head unit which is a bit annoying as it a decent double din alpine full screen that came with the car.
Post #718733 20th Jul 2018 12:28pm
Check your fader on your HU is balanced 50/50 front and rear. ๐Ÿ‘๐Ÿป (You May have already already done so. $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #718743 20th Jul 2018 1:25pm
markalpha
England 2013 Defender 110 Puma 2.2 XS CSW Santorini Black
Had a similar problem when my Alpine head unit died and I swapped to a Pioneer head unit.
Still havenโ€™t solved the problem, apart from using my sons mega boom Rolling with laughter
Post #719246 23rd Jul 2018 1:08pm
DefenderSmith
I have the same issue with focal speakers in the rear. Can hear a little bit of sound so know the wires are connected but very quiet.
Mine is powered by a single DIN pioneer head unit.
Post #728468 11th Sep 2018 8:46am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
A bit of a random one. But how are you playing the music? I had a aux cable from my phone which was faulty and caused mine. It wasn't till I put a CD in it which I hadn't done in months and all speakers worked fine I realised 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #728470 11th Sep 2018 9:30am
