![]() | Home > Technical > Gearbox Breather thread |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17703 ![]() ![]() ![]() |
The thread is M14 x 1mm pitch, the centre bore is 8mm with a tapered lead at the outer end, and the hex is 21mm across flats.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Gearbox end of breather pipe: ![]() Click image to enlarge Bellhousing end of breather pipe (I didn't measure the hole but it is marginally bigger than the gearbox end, probably 9 or 10mm): ![]() Click image to enlarge |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
You sir are a gentleman and a scholar
I think it is likely that you could tap a 1/8" BSPT thread into the hole in the centre of the fitting.
