Home > Maintenance & Modifications > Puma Aircon!! |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 |
The system was re-gassed at my local Kwik-fit, I asked if the system was holding pressure & was assured that it was. The guys there didn’t have any idea to what the fault was but didn’t even charge so more than fair.
Will check there’s 12v at the plug in the morning & take it from there. Just like to say how much I appreciate the help from members on here. |
12th Jul 2018 8:28pm |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1325 |
Check Fuse 28 (20Amp) as well Timcat . That's the fuse which covers the compressor and air con cooling fan relays. If the fuse is good, locate those two relays shown on the wiring diagram (R181 & R117) and feel/listen to them to see if they click when the A/C button is pressed. I can't remember if the electric cooling fan runs all the time on mine when the air con is switched on, or if it only cuts in when needed.
If fuse 28 is good and the R181 relay doesn't click, then it could be the relay that has failed. In which case there won't be 12v at the compressor. Or it won't click if the ECM is not sending a signal to it , due to an open circuit from either the thermostatic switch or trinary switches shown on the diagram. Might be worth checking for a click on the relay 1st before testing for 12v at the compressor. |
12th Jul 2018 9:00pm |
Either way will work. If the compressor is getting power then the relay is working, if it isn't then check the relay. |
12th Jul 2018 10:10pm |
Right, checked the power at the compressor & nothing. Back to the board & nothing from the relay, I’m not great with electrics but pulled both 10A & 20A fuses again which were fine so checked there was power there which there was. Put two new fuses in and hey presto power at the compressor & aircon up and running😬😬 Out of interest I swapped the fuses around and found the 20A hadn’t blown but wasn’t letting power through it ( had the same problem with my 690 KTM last year)
So, many thanks to all that have helped it will make the world of difference in the cab. |
13th Jul 2018 8:04am |
Click image to enlarge The set up.. |
13th Jul 2018 8:06am |
Result !!!
13th Jul 2018 8:20am |
I have had blade fuses in the past, where they test as ok on a continuity test, but won't let power through. I've never worked out why!
13th Jul 2018 10:32am |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
Off topic.....
What roofrack do you have please? I'm looking at getting the ostrich wing but will have to make my own brackets for fixing it. Just wondered how you attached yours. Glad you got the Aircon working |
13th Jul 2018 10:38am |
It’s the Landrover expedition one, my brother fabricated some last minute mounts for it the day before we left. What rack have you got?
13th Jul 2018 10:59am |
Thank you for the information.
I have a Brownchurch LR10/95/110... http://www.brownchurch.co.uk/products/roof-racks/defender/ Was it easy to assemble? |
13th Jul 2018 11:10am |
Depending on how high you want to mount it you could drill straight through the top rail ( guessing 25mm+ box section) As for the institutions they’re super vague, what a great product you won’t be disappointed. Pm me & I’ll send you some mounting pics.
13th Jul 2018 11:34am |
