![]() | Home > Puma (Tdci) > Air Conditioning issue |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1809 ![]() ![]() ![]() |
My FL1 used to slow the engine when the AC kicked in, if you remove the top belt cover off the aircon compressor, you should be able to see the compressor kicking in and out of drive, if its cycling, perhaps it needs re-gassing?
It is normal, it is the ON-OFF cycles of the aircon. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
2 to 3 seconds souds like abnormal cycling unless you live in the Arctic circle. More likely short on gas causing low pressure switch to cut the clutch in and out. Puma 110 - gone
Series III 1973 - going strong |
d92qyh Member Since: 08 Apr 2011 Location: UK Posts: 6 ![]() |
Thanks for the replies. I will take it to the garage this week. Hoping it is just gas...had a couple of td5's before but not had this puma long but it certainly doesn't seem normal.
Had it looked at today and it was over filled hence the over pressure sensor kept kicking in. [/list]
