Home > Puma (Tdci) > PUMA OEM radio wiring diagram
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Does anyone have the PUMA OEM radio wiring diagram (colours etc....)
Post #66616 8th Apr 2011 9:30am
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Isn't it standard ISO connector? Like here:
http://fordtransit.org/forum/viewtopic.php?f=54&t=78130
I have replaced OEM with Kenwood KDC-BT60U and it is simple plug&play switch. Janusz
www.yahodeville.com
Post #66633 8th Apr 2011 10:54am
mse
it is standard - what do you need? Mike
Post #66670 8th Apr 2011 5:47pm
dgardel
Italy
Socket A and socket B (ISO-DIN Connector pin-out), forgot C1, C2, C3
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #66698 8th Apr 2011 9:12pm
Marius
Thanks for the diagram. Just what I needed. In the end the alpine head unit fitted into the oem connectors.
Post #66851 10th Apr 2011 8:44pm
Another fascinating diagram, thanks!
Why does the radio unit have a reversing lamp signal? What happens when it goes live?
Has anyone fitted a "Becker CD Changer"?
Post #66877 11th Apr 2011 10:22am
dgardel
Italy
reversing lamp signal is needed for the NAVI unit like mine.
and yes I have the Becker cd charger unit installed (inside the armored Mantec cubby)
IID Pro MV License
Post #66878 11th Apr 2011 10:27am
Marius
DGARDEL, Where did you get that temperature meter in the dash?
Post #66880 11th Apr 2011 11:34am
dgardel
Italy
Here
See also:
Click me Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #66892 11th Apr 2011 2:53pm
TallPaul
C1 is usually for an external amp in high end units
C2 is usually phone connection and steering wheel controls
C3 is usually CD changer bus
Assuming almost standard mainstream german unit wiring Wink
Having speed sense on the block already is very useful, is it definitely there in the Defender?!
EDIT: AH I just realised that's your becker unit manual not the Defender wiring Embarassed Disco 3 gone but the memory of the bills remain...
XS 110 Utility maybe one day..... (did they fix the quality yet?)
Post #66919 11th Apr 2011 7:07pm
TheTechnobear
Spain 2007 Defender 110 Puma 2.4 SW Chawton White
I've just attempted to install a new alpine unit in the truck, and the unit appears to have no power
Checked fuses, and they are fine.
Can anyone tell me how the wiring is connected usually, i.e. where does the cable to the OEM plugs run to?
Whilst installing I found a couple of oddities, and I'm wondering if the wiring has been messed with...
cabling seemed to tidied away with sticky tape, and seems to run down LH side of centre console in foot well -
I'm guessing this is not standard LR (for a defender that came from LR radio ready, no unit)
Also the attenae connection, seem very very tight... Not sure it fits really!
Post #106398 12th Dec 2011 4:49pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I put an Alpine CDE-126BT in mine a few month back, and it simply plugged into thr LR loom and everthing worked perfectly. No cutting or splicing or anything unusual required. Maybe yours has been interfered with.
Pete
Post #106536 13th Dec 2011 12:02am
