Home > Technical > Anyone know what this is?
Page 1 of 3 123>
Grenadier
Thanks in advance Thumbs Up
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #713009 18th Jun 2018 2:53pm
AndrewS
Yep Thumbs Up 130's have feeling's as well you know Smile
Post #713010 18th Jun 2018 3:03pm
Grenadier
Wwwwell? Whistle Monsieur Le Grenadier
Post #713012 18th Jun 2018 3:07pm
AndrewS
http://www.paddockspares.com/ruc105200-drive-flange.html 130's have feeling's as well you know Smile
Post #713014 18th Jun 2018 3:12pm
Grenadier
Mmmm, I can see now what it looks like. To explain, my Def has developed a fault (to put it mildly) in or around the transfer box/Gear box, whilst on hols in Spain. They have sent me an estimate for the works and apparently stated that this item needs to be replaced. (platina de accionamiento). I can only assume they have made a mistake as I am unsure why this part would have any bearing on not being able to get into gear after a loud clunk and some griding. Also, in spain they seem to cost 122€ Shocked
Any thoughts on what they might have confused it with? Monsieur Le Grenadier
Post #713016 18th Jun 2018 3:33pm
V8GPC
for £4.92 looks like it may be made out of diarylea https://www.dairylea.co.uk/
Post #713017 18th Jun 2018 3:35pm
Martin
Site Admin
platina de accionamiento is "drive plate" so may be not necessarily the drive flange pictured.
Have you got a part number from them?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #713018 18th Jun 2018 3:36pm
Grenadier
Thanks Martin.
LLRO30054 Monsieur Le Grenadier
Post #713020 18th Jun 2018 3:37pm
JOW240725
Are you sure it's not the dreaded output shaft?? Having just had mine replaced. Evil or Very Mad James
Instagram @suffolk_rovers
Post #713021 18th Jun 2018 3:40pm
Martin
Site Admin
LR030054 that should be (LR's service system puts an extra L in, and people think LRO from the magazine)
Anyway, gives:
Transfer box output flange
£100+VAT full UK retail price, or blue box pattern part around £50+VAT
But might be the dreaded failure Sad http://www.defender2.net/forum/topic59735.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #713022 18th Jun 2018 3:41pm
Grenadier
Based on noise and how it failed (one hour after disembarking the ferry, but fortunately actually 50m from the dealer) I did wonder if this was the issue. Do Ashcroft do an uprated version or is the stock version fine if properly lubed? Embarassed Monsieur Le Grenadier
Post #713023 18th Jun 2018 3:43pm
JOW240725
I discovered this after I had mine replaced... https://lofclutches.com/shop/tdci/tdci-out...cba1185463 Enter 'angrypuma10' gets 10% Discount at checkout. Hope this is OK to say?? Shocked
Or https://www.ashcroft-transmissions.co.uk/m...l?page=all James
Post #713025 18th Jun 2018 3:50pm
Grenadier
Thanks for the links. If they do confirm it's the problem I think I'll head down Ashcroft route. I wonder if anyone has had the newly designed MT82 LR kit installed? Was this done for the last few releases or indepedently because of the continuing problems?
Also, the DC has done 62k (miles) would it be worth doing the clutch at the same time? Monsieur Le Grenadier
Post #713029 18th Jun 2018 4:01pm
I don't think there is anything "new" about that kit and LR hasn't changed the design of the coupling at all during the Puma production run. The only change was the inclusion of the unidentified pàste as lubricant (which is I think in fact Weicon anti-seize paste).
At that mileage I would definitely plan to change the clutch since the typical life expectancy of even the latest Puma clutches is still only 50k to 75k miles before the springs start to take on a permanent set.
Post #713067 18th Jun 2018 7:12pm
zsd-puma
What do you mean by not being able to get it into gear?
You can't actually select gears, or you can select them, but you have no drive.
If you can't actually select gears with the engine running, then it's likely the clutch has jammed which could be described as a 'drive plate'.
If you go here, you can download the Haynes Technical Dictionaries in a range of languages.
https://haynes.com/en-gb/foreign-language-dictionaries
Post #713079 18th Jun 2018 7:57pm
Page 1 of 3 123>
