Home > Tdi > 300tdi fuel leak from injection pump.
MuddyChris300tdi
United Kingdom 1995 Defender 130 300 Tdi HCPU Alpine White
Afternoon all. I’m just doing some bits to my 300tdi and noticed a leak from the back of the injection pump. Everything seems nice and tight so am wondering if it’s an internal seal. What do you helpful lot think?
It’s seems to be leakin from the back of the torxs bolt (see picture)
Thanks Chris.
Post #712625 16th Jun 2018 2:32pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Unusual", its usually the arm seal, i would try tighten that tork screw,
Post #712631 16th Jun 2018 3:35pm
MuddyChris300tdi
There all tight. I will have to dig a bit deeper.
Post #712772 17th Jun 2018 1:30pm
Retroanaconda
Assuming none of the pipe unions are leaking, it could be the o-ring that goes between the distributor head housing and the main body of the pump. Lower right on this diagram:
Post #712820 17th Jun 2018 4:55pm
Haggz
Australia 1986 Defender 110 300 Tdi CSW Alaska White
I’m having an identical issue on mine at the moment. Did you ever find the problem in the end?
Post #904178 21st May 2021 1:07am
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
Every time I’ve had a problem with the pump leaking it’s been the large o-ring sealing the high pressure side of the pump. There is a cheap kit from dieselgeek that solves the problem nicely. Their kits are intended fir the VW Tdi, but the pump is the same. Can be a bit fiddly to install but there are some tricks.
Post #904286 21st May 2021 1:28pm
Mo Murphy
Check it's not dripping down from where the leak off pipe goes back into the FIP. The rubber tube gets old and splits.
50 Shades of Pennine Grey
Post #904333 21st May 2021 6:23pm
natyeo
United Kingdom 2014 Defender 90 Puma 2.2 HT Santorini Black
Hi Folks got a similar problem , saw leaking diesel from that side of the engine, looked on net and thought it might be the rear of the injector pump , but no leak there , when running coming from timing cover, took the wading bung out to find a good pint of diesel, so timing belt kit ordered, does anyone know if what the seal part number or where to get one for front of injector pump , if it makes any difference its a 200 tdi version 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility
1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going
1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms
1971 Series 3 88, Perkins 4203,M8000,SATs,O/D,
Post #956600 26th Jun 2022 7:27pm
natyeo
Going to give this a go
https://www.ebay.co.uk/itm/151866208470?ss...2749.l2649 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #956611 26th Jun 2022 10:16pm
natyeo
Stripped down , little bits of rubber and diesel all over , belt teeth still in one piece , now whether to to do pump seal myself or send it somewhere 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
Post #957176 3rd Jul 2022 4:51pm
