Home > Tdi > 300tdi fuel leak from injection pump. |
Blackhat90 Member Since: 31 Dec 2016 Location: Forfar Posts: 86 |
Unusual", its usually the arm seal, i would try tighten that tork screw,
16th Jun 2018 2:35pm |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
There all tight. I will have to dig a bit deeper.
17th Jun 2018 12:30pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2640 |
Assuming none of the pipe unions are leaking, it could be the o-ring that goes between the distributor head housing and the main body of the pump. Lower right on this diagram:
Click image to enlarge |
17th Jun 2018 3:55pm |
Haggz Member Since: 21 May 2021 Location: WA Posts: 1 |
I’m having an identical issue on mine at the moment. Did you ever find the problem in the end?
21st May 2021 12:07am |
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 |
Every time I’ve had a problem with the pump leaking it’s been the large o-ring sealing the high pressure side of the pump. There is a cheap kit from dieselgeek that solves the problem nicely. Their kits are intended fir the VW Tdi, but the pump is the same. Can be a bit fiddly to install but there are some tricks.
21st May 2021 12:28pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
Check it's not dripping down from where the leak off pipe goes back into the FIP. The rubber tube gets old and splits.
21st May 2021 5:23pm |
natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 136 |
Hi Folks got a similar problem , saw leaking diesel from that side of the engine, looked on net and thought it might be the rear of the injector pump , but no leak there , when running coming from timing cover, took the wading bung out to find a good pint of diesel, so timing belt kit ordered, does anyone know if what the seal part number or where to get one for front of injector pump , if it makes any difference its a 200 tdi version 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
26th Jun 2022 6:27pm |
Going to give this a go
https://www.ebay.co.uk/itm/151866208470?ss...2749.l2649 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb 2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
26th Jun 2022 9:16pm |
Click image to enlarge Stripped down , little bits of rubber and diesel all over , belt teeth still in one piece , now whether to to do pump seal myself or send it somewhere 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb 2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
3rd Jul 2022 3:51pm |
