Home > Maintenance & Modifications > Puma Air Con Retrofit
It's been a while since I did this, but I've just come across the photos I took, so I thought I'd share.
So here's a (very) brief guide as to what is required for anybody thinking of doing it, it's not too hard as nothing really needs modifying and it all fits in existing spaces.
First the condenser fits between the rad and intercooler.
The fan fits to existing holes, no drilling required.
The receiver drier fits to the inner wing, seen in front of brake res. Also air con pump fitted.
Remove the dash, all of it Mr. Green as the heater box needs to come out.
The evaporator fits into the heater box.
Wired and plumbed, the dash goes back with oe button.
Voila, 2.5c ! This can be set to whatever.
Post #710547 3rd Jun 2018 7:31am
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Really nice job Greeni.
Definitely a step up from this budget alternative I saw earlier.
https://www.instagram.com/p/BkpCpbInpiA/
Post #715279 30th Jun 2018 10:15am
Grenadier
Re: Puma Air Con Retrofit
Hi Greeni,
Great photos, thank you. I'm half way through, having tackled the 'behind the dash' phase. When the DC returns from it's malaise in Palma in two weeks time, I'll do the engine bay bits, so those photos are really useful. IF you have any more you can PM that'd be great. Bow down
Quick question on the last photo where you say you can set it to whatever you want. Can you talk me through how that's done? Our summers normally exceed what the UK deems a heatwave ( Whistle ), and we regularly head further south to Italy and Spain, so I'd be keen to get it low. How do you do it? Any reason or advice as to what a lowest limit should be (with regard to over-working the sytem etc). Ta Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #715283 30th Jun 2018 10:32am
Bluest
If your system is too effective you’ll suffer from icing up of the evaporator which could temporarily restrict or block the airflow through the ventilation system. Most OE systems will not operate when the ambient is below a pre determined value to prevent this. In a hot climate I would guess it is unlikely to be a problem, but you need to consider whether you’ll want to use the system in cooler weather for demisting. 2007 110 TDCi Station Wagon XS
Post #715292 30th Jun 2018 11:22am
Grenadier
Thanks Bluest. The problem here is ambient temp can very from -20c up to +35c. Huge variance. I will get a heated windscreen fitted this year, so hopefully usage for demisting is less important than cooling in hot temps. Further I have completely done the insulation, so hopefully it will regulate the cabin a little more efficiently, winter and summer. Will be sensible with the setting Thumbs Up Monsieur Le Grenadier
Post #715313 30th Jun 2018 1:52pm
Yes, you can set it as required, that was just a test and we turned it up.
There's a minimum setting which is either law, or a manufacturing standard, but I can't remember what it was.
Due to people in hot countries stepping out of their freezing air con car and into instant heat and dying from heat shock. It's basically opposite to why people shouldn't jump into our lakes in the weather we have now..
Post #715372 30th Jun 2018 8:08pm
Wow, a sensible post, get me Mr. Green
Post #715374 30th Jun 2018 8:09pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
It's only nuts and bolts - no big deal Laughing
Bow down Bow down Bow down Bow down there you go again. Engineering masterclass Thumbs Up
Post #715377 30th Jun 2018 8:16pm
It is only nuts n bolts Cool
@grenadier, sorry I don't have more photos, but if I can help, I'll try...it was 7-8 years ago when I did it, and I'm old.
Post #715393 30th Jun 2018 9:35pm
Grenadier
Cheers, Greeni, that's all good. The photos you have help a lot. Now I've just got to wait for the DC to make it back from Palma to get started... Whistle Monsieur Le Grenadier
Post #716046 4th Jul 2018 10:21am
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Great Thread and thanks for posting, where di the kit come from? do you have a link or parts list?
Did you have to change the front nose to an AC one?
All the best
Chris
Post #716048 4th Jul 2018 10:27am
Hi, there was no need for the air con extended nose.
It was a complete kit, everything you needed, I can't remember where it came from to be honest Rolling Eyes
Answering another question, the thermostat is on the side of the evaporator and can just about be seen on the left of it, you can access the control with the door open and reaching from the footwell.
Post #716050 4th Jul 2018 10:35am
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
I've done mine recently. Got the kit from Bearmach but it's engineered by Coolair Logan who also advertise the kit on their website.
So glad I did it now with this weather, it took me 2 days to do the interior work (I'd say 6 hours a day) and then a full 8 hour day on the engine bay.
Took it to be dried, leak tested and gassed - all passed with flying colours.
I have to say their kit is different to yours - e.g. the radiator goes in front although you still don't need the extended grille and the condenser replaces the power steering reservoir bracket. I can't fault the build quality mind you, and it was very well packaged. Even came with 2 drive belts, one for spare!
If it's any help I may have the PDF manual of how to install it, will have to try and dig it out. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #716524 7th Jul 2018 12:14am
andre.prum
Luxembourg 2011 Defender 110 Puma 2.4 SW Fuji White
Hi,
I had a AC from Coolair Logan fitted to my Defender Puma 2.4..
When I start the system it work all fine, but as soon as the engine heats up (45min on the highway at 120 km/h) the AC does not manage to cool the temperature off. I even need to Censored down the ventilation as it blows from there on only hot air.
Did you experience the same issue with yours ? Ant advice would be most welcome.
kind regards
Post #914904 31st Jul 2021 3:56pm
