![]() | Home > Puma (Tdci) > Aircon stopped working |
TriniDaddy Member Since: 23 Nov 2020 Location: 10.57422, -61.28906 Posts: 29 ![]() ![]() |
You're so spot on! I left the radio bit out on purpose.
So funny enough, while trouble shooting, managed to get the radio on while the car was running saying (1 hour on) on the screen. Don't remember checking the cig outlet. The charger I have in there is ![]() So was the solution repair or replace? If I'm not mistaken, my switch was replaced in January. Will have to check the mech on that. 110 SW 2.4 IZUMI BLUE |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
In the engine bay there are two valves for regassing the system, one has a blue plastic cap and if I remember correctly the other has a green plastic cap. Take one of the caps off and you will see they are like big tyre valves. Give the stem a quick jab with a screwdriver and listen whether any gas comes out. If you hear gas escaping with gusto then you have good pressure and no leaks, if it's flat as a pancake then you have a leak and the gas has already escaped.
Not particularly environmentally friendly but you will only release a tiny amount into the atmosphere which is negligible compared with the volume that leaks off leaky vehicle AC systems and recycled fridges/freezers every day > 110 XS Double Cab |
glpinxit Member Since: 31 Jul 2010 Location: rural Somerset Posts: 156 ![]() ![]() |
Not sure if the Defender a/c system has a pressure sensor that determines whether the a/c will respond to being turned on. However, in a different car when I had a suspected leak the garage topped it up and checked if it was holding pressure. It was (for 5 minutes, at least) but to check if there was a small leak they put fluorescent dye in with the refrigerant. After a couple of days I went round the system with a UV light (normally only used by us at Halloween) and found signs of a leak/hole in the a/c radiator. This enabled most of the gas to be removed before it all leaked out, and before the system was repaired. Cheers, Guy.
It does yes. The compressor will not run without pressure being sensed. > 110 XS Double Cab
Thanks for responding guys but this is my current scenario. Nothing is wrong with the AC per say. It's purely electrical/tronic. Just waiting to see how best it could be tackled. 110 SW 2.4 IZUMI BLUE |
