Home > Technical > 2007 Puma, dash removal? How to...?
Andy730
Isle Of Man 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Hi,
Thanks for checking this out…
I need to replace the wiper boxes and drive rod on my 2007 puma defender 90. That in itself is OK, I just need to remove the dash to get to the bits…
Is there a procedure on what to remove and in what order. In other words whats the best way of doing this?
I’ve seen pictures of cars where people have removed the dash, so I know just how much is involved, but where to start…
Any advice greatly appreciated,
Andy Andy
2007 Puma Defender
2005 Volvo S60 T5 (for Sundays)
1998 MGF
Post #706193 9th May 2018 11:04am
Cupboard
To start with, the middle bit comes out by removing the obvious screws and then prying it out from around the area of the heater controls. It comes forwards then up and out. The middle air vents (but not the round ones) come with the centre section.
It then has lots of connectors behind it that you need to remove, but they're all keyed so easy enough to connect back up again. You might find it easier to remove the radio first.
Post #706201 9th May 2018 12:06pm
zsd-puma
    *Take the radio out, and remove the centre dash panel. The two screws for this are obvious, then the panel just pulls out.
    *Unplug all the switches, the plugs are all keyed so you can't put the wrong one back in the wrong switch.
    *You can either pop out all the speakers now (don't forget the tweeters if you have them), or you can wait until you can pull the dash forward a bit and just unplug them leaving them in the fascia.
    *Remove the steering wheel - centre pad just pulls off to reveal the nut - make sure wheels are straight ahead and loosen the nut to jiggle the steering wheel loose before removing the nut. - so it doesn't hit you in the face when you pull it.
    *Remove the speedo cluster, the screws for this are obvious.
    *Remove the steering column switches - the screws for the plastic cowling are obvious, but ignore the one that sticks out right at the back, it's just a stud, the cowl will slide off it.
    *remove the passenger side grab handle - again obvious screws.
    *Work your way around the outside of the dash fascia removing all the small screws.
    *Pull the dash out.
It's not that much work at all, nothing is really hidden.
while you're behind there, put duct tape on all the heater duct joints to get them sealing better. Some of the trim clips that support them are also a poor fit. replace them with zip ties.
Post #706202 9th May 2018 12:07pm
Grenadier
Awesome ZSD, literally yesterday I just stripped the DCPU to get started on sound insulation and speaker upgrade. Need to fix the heater controls whilst in there. But given the dash is 50% stripped I thought I'd do the whole lot and get behind it for more sound proofing, but also do exactly as you say and tidy up. Glad the explanation implies it's not too hard!!
Whilst I have you, do you know where the 10AS alarm unit is normally house? On stripping the doors it seems I have central locking (actuators at least, with wiring running behind the dash) but it doesn't work. Want to check what's wrong/missing etc.
Thanks in advance
Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #706212 9th May 2018 1:31pm
Andy730
All OK to all...
I'm currently awaiting for the new parts to arrive.. This little job is made easier by the fact i've currently got the instrument cluster held in place by just two screws as i've just completed a repair to the instrument cluster PCB to rectify various issues with starting etc...
OK, when the parts arrive, looks like i'll be busy again...
My thanks to you guys for the advice.
Cheers Andy
2007 Puma Defender
1998 MGF
Post #706215 9th May 2018 2:23pm
I think the biggest pain you may have is the steering wheel, but even then no trouble touch wood.
Handling it once off may also be a bit of a to do, but generally not too bad.
When you pull the steering wheel be sure to not completely take the nut off so it doesn't hit you in the face.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #706250 9th May 2018 6:53pm
zsd-puma
Thanks in advance
Thumbs Up
I think its roughly behind the instrument cluster from memory.
Post #706256 9th May 2018 7:14pm
It should be accessible if you remove the RH speaker. Darren
Post #706261 9th May 2018 7:39pm
NickMc
You an see it if you remove the drivers side lower speaker.
Post #706306 9th May 2018 9:13pm
the_lincs_landies
Hi all, great advise on this thread and I will certainly be utilising it all at some point soon (hopefully) 🙂
Out of curiosity, do the heater controls need to come off for the dash to be free, or are these on a mounting point in behind the dash? I only wonder as some sellers of second hand dashes seem to be selling with the controls, and some without.
Thanks
Kieren
Post #1004312 16th Aug 2023 6:35am
The sub-panel with the heater controls is attached to the main dash-panel moulding, but does not have to be removed from the vehicle if you want to remove the dash-panel moulding. It is not attached to the centre panel (the one with the radio and switches etc) and stays win place when that is removed. Removing the centre panel reveals the screws holding the heater control sub-panel to the dash.
The photos below (found online some years ago) show the arrangement.
Referring to the OP's post at the start of the thread (which I know is five years old), it is worth noting that you don't need to remove the dash to replace the wiper motor, drive rack, wheel-boxes or drive rack guide tube, you merely need to free the dash and ease it away from the bulkhead. This can be done without the wholesale dismantling and disconnection of everything dash-related and is covered in various threads elsewhere on this forum.
Post #1004320 16th Aug 2023 9:15am
the_lincs_landies
Thanks as ever, blackwolf. Unfortunately for me its a full removal as i need to replace the firewall/bulkhead mat, and the dash moulding due to various bits having been chopped out historically.
This one next to the switch panel, for example... a couple in the section under the steering column, to name but a few.
So, judging by the second pic of the LHD defender, it would need to be unbolted, but not fully disconnected?
Post #1004341 16th Aug 2023 11:59am
the_lincs_landies
Additional Question
Additional Question.. Is the Defender 90 and Defender 110 interior the same, it is, right? E.g. A replacement dash from a 90 would fit my 110?
Post #1004344 16th Aug 2023 12:12pm
Should be essentially identical on all TDCi vehicles (switches etc may differ of course, but the core structure is the same on all.
It's actually the same dash for LHD and RHD vehicles right up to the moment when a huge hole is hacked in one side for the instrument panel. I don't know, if you were to buy a new one, if the hole is pre-installed or you have to buy the hole separately and fit it yourself. Laughing
Post #1004360 16th Aug 2023 2:48pm
the_lincs_landies
Hacked is the right word, I have seen the quality of the cuts where my instrument cluster is!
I am reassured that its the same for 90 and 110 - I thought that was the case but the salvage yard seller I bought my dash from on eBay was listing 90 and 110 ones as specific to the model. eBay did its usual "this wont fit your vehicle" trick, because the seller hadn't populated the other defender models, but i took the punt as the 90 dash was the best condition.
Next I need to work out how to replace my shabby firewall mat/pad... managed to get one that hadn't been cut in half (rare as rocking horse Censored ), so want to get it in in one piece as well! Oh well, one problem at a time. Dash out first.
Post #1004365 16th Aug 2023 3:09pm
