Home > Puma (Tdci) > key fob in to the washing machine
Eduardo
Hi there!
Regrettably my son lets the key in its pants and put it in the washing machine (at least he his doing its homeworks)
I rescue it, open it and dry it but regrettably doensnt work anymore Sad
Still I have the second pair and I'm not in a hurry...
Any cheaper alternative that ask to the dealer?
Remember that I'm a little bit far away from UK Mr. Green
Cheers! Eduardo
Post #704217 30th Apr 2018 6:10pm
zsd-puma
Get a second hand Rover fob from ebay. So long as it's marked 3TXB or 17TN on the back it will work. You just need to get someone to program the car to recognise it. (about 10 min work with a diagnostic machine) Rover 100's, 200's, 400's, Mini's, MGF's, Discoveries and TD5 Defenders all use the same fob.
If the used one you get is a bit worn, Land Rover still sell new cases and button kits for them (about £12)
Post #704326 30th Apr 2018 8:34pm
dolver
I’ve used this website before. The new keys certainly work and they let you know the EKA code. You get a part refund when you post back the programmer (in the pre-paid envelope)
https://remotekey.co.uk/land-rover/
Would recommend them.
Post #704369 30th Apr 2018 9:08pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Combined key and fob looks good.
Post #704400 30th Apr 2018 9:37pm
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
Washed one before and changed battery it worked once dry. Guess I was lucky
Post #704431 30th Apr 2018 10:24pm
LR90XS2011
take the battery cover off spray with ACF 50 shake and dry refit new battery try again. Worked with a phone I dropped in a river, nothing too loose. DEFENDER 90 TDCI XS,
Post #704463 1st May 2018 6:12am
Eduardo
Thanks
I will try again to see if will work again, if not, thanks for the alternative!
Cheers Eduardo
Post #705221 4th May 2018 2:24pm
I have reprogrammed a new key fob myself, however, there is a procedure to it and you need the correct equipment.
It's not something I will discuss publiclally for obvious reasons.
Repacing them is not very expensive at all, nor programming. TheThunderRolls🇬🇧🇺🇸
Post #705222 4th May 2018 2:29pm
gilarion
Put the key fob in a bowl and completely cover in dry uncooked rice for 24 hours works wonders believe me For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #705235 4th May 2018 4:19pm
gilarion
Brown or white rice either will work Thumbs Up For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #705236 4th May 2018 4:22pm
VeeTee
Netherlands
Or buy some Silicagel Crystal Cat Litter, absorbs moisture better than rice. Thumbs Up Cheers, Vincent
MySite
Post #705271 4th May 2018 6:44pm
AMBxx
Learning from my wife's experience, Kindles can survive a trip around the washing maching, Blackberry phoes can't. Whistle
Post #705367 5th May 2018 7:22am
