Home > Td5 > Td5 stereo
chinnus
2001 Defender 90 Td5 ST Coniston Green
Td5 stereo
Hi all,
Have a problem with my factory installed stereo. It works very intermittently and I believe it’s somethinf to do with the power supply to it.... I havnt found any patterns of it working or not working it’s just random
Before I investigate tomorrow wondered if it was a common problem and where I should look?
Thanks in advance
Post #702498 22nd Apr 2018 8:59pm
bluebottle
Checking the connections are all sound would be my first port of call. Get a multimeter on the wiring if it 'looks' ok.
Post #702717 23rd Apr 2018 9:18pm
4RF RDS
Pull it and get at the plugs on the back. Check all the wiring as stated above. There really is no “common failure” thing with radios like this that I am aware of.. good luck! 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #702720 23rd Apr 2018 9:21pm
watergypsey
United Kingdom 2006 Defender 90 Td5 HT Zambezi Silver
I hade the same problem ,i mtook unit out and the clip had broke on the iso fittings so was rattling loose ,easy fix for me Smile
Post #709167 25th May 2018 5:47pm
