Home > Td5 > Td5 stereo |
chinnus Member Since: 24 Aug 2012 Location: UK Posts: 119 |
Hi all,
Have a problem with my factory installed stereo. It works very intermittently and I believe it’s somethinf to do with the power supply to it.... I havnt found any patterns of it working or not working it’s just random Before I investigate tomorrow wondered if it was a common problem and where I should look? Thanks in advance |
22nd Apr 2018 8:59pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 933 |
Pull it and get at the plugs on the back. Check all the wiring as stated above. There really is no “common failure” thing with radios like this that I am aware of.. good luck! 👍 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
23rd Apr 2018 9:21pm |
watergypsey Member Since: 16 Apr 2018 Location: oundle Posts: 25 |
I hade the same problem ,i mtook unit out and the clip had broke on the iso fittings so was rattling loose ,easy fix for me
25th May 2018 5:47pm |
