Home > Maintenance & Modifications > Aircon |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5804 |
Good to hear Dan, well done. Still wondering whether I DIY fit or go garage? I will be stripping the Def shortly to add sound proofing, so maybe it wouldn't be as much of a job as you found it? Was it technical? And what's Rave? Is that a Typo or something I should consider using? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
28th Apr 2018 8:24am |
I was wondering about this actually. Does AC actually make an Intercooler less effective as the fan partially covers it? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
28th Apr 2018 8:26am |
^^^ You wouldn't believe how sensitive I am to changes in the Def. I notice every little nuance. I have the hands and skills of Lewis Hamilton. Honest.
So losely speaking, only use the AC when absolutely neccessary, such as steady M-way driving. Remainder of the time, for maximum omph, hoon around with the windows open. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
28th Apr 2018 9:21am |
dantastic Member Since: 04 May 2010 Location: London Posts: 367 |
Rave is Land Rover's internal repair manual. Freely available on the internet.
It's not what I would call a DIY job. If you are comfortable ripping out the entire dash down to the bulkhead then fine, just go ahead and do it yourself. |
29th Apr 2018 9:12pm |
I'M happy ripping stuff out, it's the reassembly that worries me
Happy to tackle most labourious, manually difficult jobs and being France I have stacks of Bank Holidays coming up in May. Greatest fear would be more about wiring, is there much to it? Tried to find a copy of the Rave, do you have a link or could you send me a PDF if I PM you my email address? Ta Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
30th Apr 2018 1:59pm |
Piece of cake to reassemble this, no?
Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
30th Apr 2018 2:07pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3254 |
/\/\ That photo gives me the horrors!
30th Apr 2018 2:08pm |
Mmmm Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
30th Apr 2018 2:16pm |
That's nothing, you want to try re-shelling a whole car Ray
30th Apr 2018 2:23pm |
@eric, that's only half ways there. You need to get down to the heater box and remove that too.
Ah the wiring is very easy. If you have the 2.2 you have to run a cable to under the seat box but if you have the 2.4 you're singing. Here's a linky to rave btw. https://www.dropbox.com/s/6kpm7zbfhxtmwqx/...e.pdf?dl=0 |
30th Apr 2018 4:24pm |
Thanks
Will give it a read and see if I'm up to it Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
1st May 2018 3:30pm |
Dantastic, think I'm going to be taking the dash off today, the DC's been fully stripped back for sound proofing, speakers and general tidying of wires etc. Also need to repair the heater controls. Would this be a good moment to sort out these aspects of the aircon and can it be done in this order? If so, have you got a quick heads up as to what needs to be done at this stage in the cAbin and behind the dash, bar the obvious fitting the button and wiring it in? Monsieur Le Grenadier
10th May 2018 6:31am |
If you have it all out then yea, ideal timing!
Not that much needs to be done bar stripping. You need to take the heater box out and install the evaporator into the heater box. This is the biggest job. You also need in install the relay holder by the under steering wheel fuse box but this is very simple. Need to run a small bit of wiring loom but all this can be done with your eyes closed. Getting to and getting the heater box out is the tricky bit. The only thing that wasn't immediately obvious to me was the temp sensor. You need to stick it in between the fins somewhere in the middle of the evaporator. Might be obvious but I was scratching my head for a few moments when it just said "fit like in the picture" and the pic corresponding to the number was missing from the instruction! |
10th May 2018 12:02pm |
Dan, got to the point where everything is stripped, heater box 95% removed, but just one question. How/where did you clamp the in/out flow pipes to the box? And what type of clamp did you use? Can’t figure it out. Keen to do it today. Monsieur Le Grenadier
27th May 2018 7:56am |
