Home > Puma (Tdci) > Crazy wipers
Smithy
Crazy wipers
My 2012 Puma wipers decided to go crazy (no fast speed and wouldn’t turn off) turns out to be the park switch not the stalk.
The switch is located on the passenger side and is relatively easy to replace without removing the bulkhead panel.
I removed five top mounted screws, the grab handle, speaker and five bottom mounted screws and the two screws in the front radio panel.
The bulkhead panel pulls out far enough to access the park switch. To remove the switch you have to prize it out slightly and then pull upwards then reconnect the plug and spade connectors.
Hope this helps!
Post #700113 11th Apr 2018 3:03am
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Top tip, cheers
Thumbs Up Mr. Green
Post #700128 11th Apr 2018 6:59am
JellyBean
Thanks for tip, Smithy.
Post #700131 11th Apr 2018 7:08am
Jakkals
South Africa 2010 Defender 110 Puma 2.4 SW Keswick Green
Jip, need to do this on my Landy too. you make it sound very simple.
Post #700206 11th Apr 2018 2:35pm
