- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Smithy
My 2012 Puma wipers decided to go crazy (no fast speed and wouldn’t turn off) turns out to be the park switch not the stalk.
The switch is located on the passenger side and is relatively easy to replace without removing the bulkhead panel.
I removed five top mounted screws, the grab handle, speaker and five bottom mounted screws and the two screws in the front radio panel.
The bulkhead panel pulls out far enough to access the park switch. To remove the switch you have to prize it out slightly and then pull upwards then reconnect the plug and spade connectors.
Hope this helps!
11th Apr 2018 3:03am |
Badger110
Top tip, cheers
11th Apr 2018 6:59am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
