![]() | Home > V8 > Tdi to V8 |
PumaPhil Member Since: 26 Oct 2014 Location: Bridgend Posts: 201 ![]() ![]() ![]() |
Thanks Mike, I'll have a look for your build thread.
Having driven hundreds of miles with both gearboxes over the years, in both TDI and TD5 vehicles I think I am one of the few people who actually prefers the LT77 to the R380, so plan is to stick with this 'box if I can. I feel that as I will be changing the engine and chassis, if I also change gearbox type, bulkhead, seatbox and floors I will have very little of the actual original car left. Although this is probably from a sentimental view more than anything - the 90 has been in the family since it was new in 1990. |
charcoal Member Since: 28 Jul 2014 Location: Hampshire Posts: 942 ![]() ![]() ![]() |
Sorry but your wrong on this one. A vehicle with the LT85 has the gearstick about two inches further forward than a 77 or 380 so if it was mounted in the same position then it would indeed be two inches too far back. However the selector housing on both gearboxes are different. LT85 is on the gearbox itself and LT77 is raised a little and a bit further back. Trying to fit an LT85 to a LT77 vehicle would put the engine two or so inches back and vice versa which is clearly where your confusion is from. Had this problem when I did my v8 conversion which put the engine in the wrong place and had it moved and transmission tunnel cut so the gearbox could be in the correct position(for LT85). LT77s diesel and petrol are exactly the same except for input shaft, bellhousing and fifth gear different ratio and are mounted in the same positions giving the correct engine placement. 1999 Land Rover Defender 110 td5 station wagon 1998 Land Rover Defender 110 County Station Wagon ~ Sold 1995 Land Rover Defender 110 V8 Station Wagon ~ Sold ![]() 1985 Land Rover 110 ex mod project Tithonus ~ Sold ![]() |
Blanc Member Since: 14 Jul 2016 Location: Suffolk Posts: 43 ![]() |
Possibly a bit late but I've converted my lt77 gearbox 90 to a V8. It was originally a 2.5 petrol but spent a couple years with a 200tdi on the same mounts before I rebuilt.
I had a v8 spec chassis from Richards and as I wanted to keep my LT77 bulkhead, floor, tunnel and matting I had Ashcroft build me a v8 spec LT77 which I think is the same as long stick Range Rover LT77. I used the lt77 V8 bellhousing from the disco 200 series donor. I theory everything should have been in factory positions but in realty ended up with the engine about 20mm to far back. I modified the bolt on engine mount brackets to leave the gearsticks etc in the right place. Propshafts remain 200tdi era Defender standard items for an easy life. All v8 hoses still work where needed. |
Thanks Blanc, not too late at all, realistically I won't start this project until next year due to work/space/funds etc It sounds like you have done exactly what I am planning. Do you have any photos of the rebuild that you wouldn't mind sharing?
