Home > Technical > heater box
Bert@E
Netherlands
heater box
solved
Post #698440 4th Apr 2018 8:33am
donmacn
Pretty sure the boxes are the same for the 300 and 200 tdi, although the actual heater matrix did change at some point - just the way the pipes ran. On the 300tdi the pipes come straight off the matrix, on other models - maybe the 200 or the TD5 - they came straight off, and then dropped downwards. I'm guessing this was to allow better pipe runs to the engine?
I've never had anything newer than a 300tdi, so hopefully someone else will chip in. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #698447 4th Apr 2018 9:03am
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
As said only difference is the top section to accommodate feed/return pipes went down upto last few 200tdi then straight
Post #698556 4th Apr 2018 4:37pm
rallysteve
The later ones (Not sure if it was start of td5 or 02' facelift) changed to a different electrical connector. Easy to rectify anyway, especially if you have one from your vehicle already.
Post #698586 4th Apr 2018 5:46pm
